Thread: Tires or Axles (Vibration)
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #21 Re: Tires or Axles (Vibration)
    Cheap parts wear out quickly.
    I'd find some with grease fittings to keep the joint well lubed so it lasts a long time. Think more in the range of 20-30 per tie rod maybe.
  2. #22 Re: Tires or Axles (Vibration)
    Jan 2012
    Philadelphia
    I agree I bought a set of the cheap tie rods about a year ago and there already shot
  3. #23 Re: Tires or Axles (Vibration)
    cheap parts are cheaply made and dont last long.
    i have duralast tie rod ends for the last 2 years, my alignment has been in and out so many times since i put them in and they are both still tight. (due to changing other parts, and one real bad alignment as well )
    i think they were about 35 a side.
  4. #24 Re: Tires or Axles (Vibration)
    GT Level Member jake91's Avatar
    Jun 2012
    mesa az
    Just wanted to update this as a possibility for others. I finally found the vibration and its fixed. New tires helped and so did a cv axle, but what finally fixed it was new engine mounts
    2003 Pontiac Grand Prix GTP, thrasher intake, intense poly upper mounts, 06+ Impala dual piston calipers, 88k miles
  1. Axles???
    By GRAND98 in forum General Tech Discussion
    Last Post: 07-13-2012, 09:10 PM
  2. What CV Axles to use
    By indygrandprix in forum Brakes/Suspension/Chassis
    Last Post: 03-13-2012, 04:49 PM
  3. Bad Axles?
    By lflylow in forum General Tech Discussion
    Last Post: 10-20-2011, 08:57 PM
  4. Don't buy these axles!!!!
    By 01RedfireGT in forum General Tech Discussion
    Last Post: 06-29-2009, 11:32 AM
  5. Axles
    By starscr33m in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2009, 09:59 PM
