Thread: '04 GTP No Heat (Blower & Temp Guage work)
Results 1 to 7 of 7
  1. #1 '04 GTP No Heat (Blower & Temp Guage work)
    Jul 2011
    Champaign County
    My '04 GTP heater didn't work when I turned it on today. The blower works fine, no heat at all....not even luke warm. The temperature guage works like always has so I was told it s not the thermostat. Will a flush help or is this a heater core issue?
  2. #2 Re: '04 GTP No Heat (Blower & Temp Guage work)
    You can try a coolant flush and see what that does. Make sure you flush the heater core and bleed the system of air really well.
    If thats not it, then start looking into a blend door problem. They are common.
  3. #3 Re: '04 GTP No Heat (Blower & Temp Guage work)
    Jul 2011
    Champaign County
    Thank you very much.....a coolant flush is in my future!
  4. #4 Re: '04 GTP No Heat (Blower & Temp Guage work)
    SE Level Member PALMCASTER GT1's Avatar
    PALMDALE CA
    If your problem turns out to be the heater core , don't tear your dash apart. It's at the bottom and not to hard to get at. Only the front seats and console come out , and then look under the dash and there it is.
    04 GT1
  5. #5 Re: '04 GTP No Heat (Blower & Temp Guage work)
    SE Level Member 99XC600's Avatar
    Apr 2012
    Wilbraham MA
    I had to flush my heater core this summer. To make it a little easier, I used a couple of washing machine water supply hoses with one of the ends cut off. Luckily the OD of the washing machine hose fits nicely into the ID of the heater hose. You can then just attach your garden hose to the lines and back flush it with no mess or stress. Just remove the hoses from the alternator bracket an insert the washer hoses and flush away.
    2004 Ivory White Pontiac Grand Prix GT1 - Bone Stock and my 80 mile daily driver.
  6. #6 Re: '04 GTP No Heat (Blower & Temp Guage work)
    you have air in the heater core, take both hoses off the alt bracket, put a garden hose to one of the hoses, and flush it till clear water comes out, fill both hoses and put them back on, you should be good to go after that.
  7. #7 Re: '04 GTP No Heat (Blower & Temp Guage work)
    Jul 2011
    Champaign County
    The Flush fixed it!!! Thank you everyone!!!!
  1. temp guage
    By leigh in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-27-2012, 12:09 AM
  2. Temp guage
    By develand in forum General Tech Discussion
    Last Post: 03-08-2012, 09:18 AM
  3. Trans Temp guage question
    By Kenny75k in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-07-2010, 04:38 PM
  4. 04 GTP Temp Guage Quit Working
    By trick94cobra in forum 04+ Specifics
    Last Post: 11-11-2009, 09:07 PM
  5. Manifold Air Temp Guage?
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2008, 05:24 PM
