Thread: Gas gauge works then doesn't...?
Results 1 to 8 of 8
2001redfireGT Gas gauge works then... 09-30-2008, 12:39 PM
ssm90GT Re: Gas gauge works then... 09-30-2008, 01:35 PM
2001redfireGT Re: Gas gauge works then... 09-30-2008, 03:04 PM
Sabrewings Re: Gas gauge works then... 09-30-2008, 04:44 PM
2001redfireGT Re: Gas gauge works then... 09-30-2008, 05:19 PM
Sabrewings Re: Gas gauge works then... 09-30-2008, 05:57 PM
gtpinsc Re: Gas gauge works then... 09-30-2008, 06:23 PM
SofaKingCdn Re: Gas gauge works then... 10-03-2008, 04:14 AM
  1. #1 Gas gauge works then doesn't...?
    SE Level Member 2001redfireGT's Avatar
    Twin Cities
    For a while my gas gauge has been mostly reading full, even though it isn't. Sometimes it fluctuates a little but I never know what the level is. So for the most part it usually just stays "full". I always have to rely on the trip counter. Now is this a common problem? Is it most likely a short, loose connection; or is it maybe something more serious, such as the fuel gauge sender unit? Any ideas?
  2. #2 Re: Gas gauge works then doesn't...?
    Bloomington, IL
    I had the same problem until i had ZZP install their SSM90 kit along with a couple other things. I mentioned the same problem you are talking about and they were able to fix it. I don't want to tell you the wrong thing since i am not totally sure how they fixed it. Email ZZPerformance and ask them about it. They will be able to tell you a better, more precise answer. Hope this helps!
  3. #3 Re: Gas gauge works then doesn't...?
    Twin Cities
    Quote Originally Posted by ssm90GT View Post
    thank you! hopefully they wouldn't mind describing what it is/how to fix it. i'll see what I can find out!
  4. #4 Re: Gas gauge works then doesn't...?
    Barksdale AFB, LA
    Fuel level sender. Replace it. Yes it's a common problem.
    2009 Subaru Impreza WRX STI
  5. #5 Re: Gas gauge works then doesn't...?
    Twin Cities
    bear with me guys, im a little new here. but how complicated and expensive is a job like that? im pretty sure there is an access panel under the trunk liner (giving access to the pump and the sender) so i dont have to drop the tank. but anything else I should know? thanks for the reassurance thus far. minor i know but it still pisses me off.
  6. #6 Re: Gas gauge works then doesn't...?
    Barksdale AFB, LA
    It's nothing difficult. Pick up a haynes manual or something if you haven't already. It'll show you how to do all that sort of stuff and you'll see it's easier than you think. It's cheap, too.
  7. #7 Re: Gas gauge works then doesn't...?
    Jul 2008
    sumter,south carolina
    mine does the same thing...comes and goes.i just deal with it and keep track of miles when i fill up.
    02 GTP with mods 05 GP for DD
  8. #8 Re: Gas gauge works then doesn't...?
    Manitoba Canada
    there is a video on youtube where a guy does one on a Bonneville (YouTube - Pontiac Bonneville Fuel Sender Replacement -- PART 1) I've never done one (but I need to) so I can't say it applies to Grand Prix's but it will probably give you a general idea, I'd think anyway.
  1. It Works!!!
    By 02BlueGT in forum PCM Tuning
    Last Post: 08-31-2008, 01:02 AM
  2. Finally! ABS Works again
    By Toofastgs in forum Brakes/Suspension/Chassis
    Last Post: 07-10-2008, 12:59 PM
  3. Can someone explain to me how a 2 Stage Nitrous kit works?
    By Iron Indian in forum Off Topic Discussion
    Last Post: 01-28-2008, 10:36 PM
  4. The Search Function Works!!! OMG!
    By Lawngoose in forum Off Topic Discussion
    Last Post: 12-27-2007, 11:07 PM
