Thread: tire pressure monitoring system light
Results 1 to 6 of 6
  1. #1 tire pressure monitoring system light
    Jul 2008
    my tire pressure monitiring system light keeps coming on for no reason. i always check the pressure as soon as the light comes on and the pressure in all tires is always good. has anyone else had this happen. and what could be causing this?
  2. #2 Re: tire pressure monitoring system light
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    This is not a solution to your problem, as im sure someone will know the solution, but could u post a pic of the tire pressure gauge?
    Ive never seen it and I would like to see where it is and what it looks like. Thanks!
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  3. #3 Re: tire pressure monitoring system light
    Jul 2008
    just go on to google and type in tire pressure gauge
  4. #4 Re: tire pressure monitoring system light
    Jul 2008
    the light came back on again today and all was still good any body have any ideas whay this keeps happening
  5. #5 Re: tire pressure monitoring system light
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    hmm...I have lo-pro tires and sometimes in the RAIN mine will come on or if i corner really fast is will also display on rare occasions...doesn't sound like a small issue because you said you check your tires and we're the same....
    might be a stupid question but after it comes on do you reset it? ( in the menu go to reset tire pressure, not just enter. that only ignores it )
    cause if you don't its just going to display it again everytime you start the car and drive a few miles
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  6. #6 Re: tire pressure monitoring system light
    Jul 2008
    no i clear it every time that it comes on and then it comes back but it didnt do it today so maybe its all good now
  1. ABS Light+Low Trac+Check Tire Pressure Problem
    By 1997gpgt in forum Brakes/Suspension/Chassis
    Last Post: 08-11-2011, 10:18 PM
  2. ABS and Tire Pressure Lights on
    By adidasdude1061 in forum Brakes/Suspension/Chassis
    Last Post: 02-16-2010, 10:05 PM
  3. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
  4. Tire Air Pressure
    By 03GPScottyd in forum Tires & Wheels
    Last Post: 08-04-2008, 11:07 AM
  5. Tire Pressure System not working.
    By xray328 in forum General Tech Discussion
    Last Post: 05-13-2008, 08:43 AM
