Thread: Oil Level Sensor Problems
Results 1 to 11 of 11
  1. #1 Oil Level Sensor Problems
    GT Level Member UCF04GPGTPCompG's Avatar
    Nov 2009
    Clermont, Florida, USA
    I've had my Oil Level Sensor replaced several times. They keep failing and needing to be replaced. Luckily my mechanic will fix them for free since I paid for the install already and the part is warrantied. It's the Autozone equivalent part. Anyone else have problems with the Oil Level Sensor failing? I'm thinking of buying the GM part for it and installing it myself, anyone know how to do it? I think I know where it is based on the diagram for it. I would think I need to drain the oil, replace the sensor, and then fill the oil back up. Just wanted to be sure that sounds right to anyone that has done it before. Any help would be awesome. Thanks!!
    2004 Pontiac Grand Prix GTP Competition Group (250K)
    Engine Mods: K&N Air Intake, ZZP 3'' Downpipe w/MagnaFlow Cat
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    After 10yrs working as an auto electrical tech one thing I can say with 100% certainty.
    DON'T BUY AFTERMARKET SENSORS (autozone, advance auto, oreIlly, napa, etc.)
    There I said it. 9 times out of 10 they are junk, dont last or give false values anyways.
    Sent from my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  3. #3 Re: Oil Level Sensor Problems
    Quote Originally Posted by rperry435 View Post
    i blew 3 of them sensors up too, they all leaked out the plug end, all pep boys or auto zone crap. right now theres a brass plug in the hole to block it off, it gets old fast.
    buy a oil pressure gauge, problem solved.
    best way ive found to change it tho is to take off the pass side tire, reach in with large channel locks and remove it with them, the large wrench has no room to work in, not worth the effort. then re install the new one just snug it up, it has tapered threads so stop cranking when it first gets tight. make it nice and snug, thats it! notice how much threads are showing on the old one before you take it out, thats as far in as it goes.
    Oct 2011
    MI
    It's attached to the oil filter housing. You don't have to drain the oil to do it
  5. #5 Re: Oil Level Sensor Problems
    Thats the oil pressure sensor/switch.
    The oil level sensor is on the side of the oil pan, in the middle.
    I vote plug as well.
    If you lose oil pressure your engine is shot.
    Unless you have a super cool aftermarket gauge that lets you know when you drop below 20, it wont help you.
    Even then, 20 psi at wot for example wouldnt be enough.
    Only time i see the point is if road racing, however oil temp would also be a concern.
    Even then, how often do you glance at your gauges?
  7. #7 Re: Oil Level Sensor Problems
    I feel like one of only a couple people that can read today. LEVEL SENSOR, not pressure sensor.
    It's on the front of the oil pan, facing the radiator. Here's a pic of an oil pan. (Same location for steel pan) See the hole in the front. Bingo... it's a large size as well and not super tight. I use a large adjustable.
    Oct 2011
    MI
    Yeah I totally read that wrong. I stand by my statements on the crappy aftermarket sensors
  9. #9 Re: Oil Level Sensor Problems
    I totally agreed with you. I cringe when someone says "I bought an Autozone maf". At least we know the problem in those cases..lol
  10. #10 Re: Oil Level Sensor Problems
    Nov 2009
    So to install a new level sensor what should I do? I think I know, as i stated in the beginning, but no one has confirmed the installation process....
  11. #11 Re: Oil Level Sensor Problems
    Ok..didn't realize you needed the step by step in that much detail. You'll understand why once you do it. Having not done it..I understand why you are asking.
    1. Jack and support car.
    2. Drain oil
    3. Look at sensor and find hole for the wiring connector's tab. You might need to loosen the sensor a half turn to find this area. Using a small screwdriver.. lift the tab up on the connector and pull it off the sensor. This will be the edge closest to the pan.
    4. Unscrew the sensor (large adjustable is my tool of choice)
    5. Check for the o-ring, it likes to stick to the pan. Pull off if needed.
    6. Check new sensor for o-ring and put new sensor in pan
    7. Reconnect the electrical connector
    8. Finish oil change with fresh filter and oil
    9. Put car back on it's wheels
    10. Smile because that's the easiest thing you'll ever do on a car beside filling the tank.
  1. Low Oil Level Light Still Comes On After Low Oil Level Sensor Replacement
    By LoveMyGPGT in forum General Tech Discussion
    Last Post: 04-23-2017, 09:20 AM
  2. low coolant level sensor
    By Jgackle in forum General Tech Discussion
    Last Post: 12-31-2012, 01:31 PM
  3. Oil level sensor question
    By basshead42 in forum General Tech Discussion
    Last Post: 06-07-2012, 06:47 PM
  4. question about low coolant sensor,fuel level sensor,and the
    By spider4 in forum General Tech Discussion
    Last Post: 11-26-2011, 09:19 AM
  5. how do you disconnect the oil level sensor from the oil pan.
    By 98regalgsx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-21-2010, 07:06 AM
