Thread: Oil level sensor question
Results 1 to 6 of 6
  1. #1 Oil level sensor question
    SE Level Member basshead42's Avatar
    Toledo, OH
    can anyone tell me if they have two or three wires goin to their oil level sensor. So far i have two goin to it .I found a wire loose thatt might have pulled out of the connector but also doesnt look like it was long enough to even go there. Maybe an inch or two short. But it is in the same wire loom...thanks
    2000 GTX--3.4 pulley, MSD wires, NGK Iridium plugs 2 ranges colder, 180* Tstat, U-Bend delete, DHP 1.0 PCM, Ram-Air, headers are next!
  2. #2 Re: Oil level sensor question
    I live here. TLSheff's Avatar
    If you can take a picture... BillBoost37 is our avid "Know-it-all" and loves a good challenge.
    With that being said, it should only be a 2 pin connector for the oil level switch. GM# 12603782 shows to use a GM# 12102747 Mating Connector (AcDelco# PT374) which shows to be a 2 wire. If it is a 3, you have an oddball setup.
  3. #3 Re: Oil level sensor question
    Jun 2012
    Somewhere
    First whats the problem other than a hanging wire? some have 2 wires some have just 1 wire. The other wire depending on motor could go to the knock sensor, or oil sending unit. And yes a pic would help. I have worked on alot of GP's over the years as a mechanic
  4. #4 Re: Oil level sensor question
    St. Louis
    Yes, the level sensor is a 2 wire unit, while I suspect that the single wire belongs to the front knock sensor that screws into the block about midway up towards the middle of the block.
    Oil pressure sending unit is on the oil filter adapter which is nowhere near the oil level sensor. What color is the single wire?
  5. #5 Re: Oil level sensor question
    Toledo, OH
    its black and was just taped up and the tip of the wire was stripped about 1/8th inch...was replacing the motor mount on the passenger side and noticed the wire sticking out of the loom...there are two wires tho goin to the oil level sensor
  6. #6 Re: Oil level sensor question
    Toledo, OH
    since it obviously doesnt go to the oil level sensor ill have to investigate it further
  1. Low Oil Level Light Still Comes On After Low Oil Level Sensor Replacement
    By LoveMyGPGT in forum General Tech Discussion
    Last Post: 04-23-2017, 09:20 AM
  2. low coolant level sensor
    By Jgackle in forum General Tech Discussion
    Last Post: 12-31-2012, 01:31 PM
  3. question about low coolant sensor,fuel level sensor,and the
    By spider4 in forum General Tech Discussion
    Last Post: 11-26-2011, 09:19 AM
  4. How to clean Coolant Level Sensor?
    By Noopsky13 in forum General Tech Discussion
    Last Post: 09-19-2011, 08:33 PM
  5. how do you disconnect the oil level sensor from the oil pan.
    By 98regalgsx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-21-2010, 07:06 AM
