Thread: 4 way flasher switch broken, $370 for part + labor...
Results 1 to 10 of 10
Threaded View
  1. #1 4 way flasher switch broken, $370 for part + labor...
    SE Level Member TomOfTarsus's Avatar
    Nov 2009
    near Pittsburgh, PA
    I was going for my state inspection last night and, as usual before heading for the garage, I went over my lights, signals brakes, reverse, 4 ways... WHAT THE...?!
    And I remembered. Last year at inspection time the fellow had to fiddle with the switch. Now the symptoms are as follows:
    4 way switch in normal (off) position - no turn signals
    4 way switch pushed down - turn signals work
    4 way switch, push a little harder - 4 ways, or fast flashing turn signals or nothing, depending on who knows what.
    Obviously there is something wrong with the switch, which has been used more for the 10 vehicle inspections it's been through than anything else. But I had to go to work this AM, 25 miles through Pittsburgh, so I was able to use a few wraps of the handyman's best friend to keep the 4 way switch suppressed.
    And of course, the switch is part of a complete harness that includes the turn signal/wiper/cruise control arm, and you need a special tool because of the airbag (in the car, not me!) and the assembly is $371 and I'm ready to choke a few of my fellow engineers.
    Any ideas? Anyone seen this before? Oh, and it's 2003 GTP.
    Thanks...
    Last edited by TomOfTarsus; 11-01-2012 at 07:28 AM. Reason: thought my vehicle specs were in my siggie... wrong...
  1. What is this part and which is broken?
    By Mara Whalle in forum General Tech Discussion
    Last Post: 09-21-2016, 06:30 AM
  2. Fan switch broken or bigger problem?
    By bvanetten in forum General Tech Discussion
    Last Post: 08-05-2011, 05:26 PM
  3. 2004+ Rear Seat Interior Light Switch Broken anyone find this part?
    By UCF04GPGTPCompG in forum Visual/Body Modifications
    Last Post: 02-27-2010, 01:39 PM
  4. someone explain what part is broken..maybe..
    By Bio248 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-17-2009, 10:22 PM
  5. Happy Labor day
    By TDCRacing in forum Off Topic Discussion
    Last Post: 09-01-2008, 09:47 PM
