Thread: W-body engine/tranny/cradle swap
Results 1 to 7 of 7
  1. #1 W-body engine/tranny/cradle swap
    fargo, nd
    I've been searching a lot for an answer to this but can't find an answer. My tranny went out on my 97 GP SE and the 3800 in it isn't very far from going out either...I have have access to a really good deal on a 2001 Buick Regal with a 3800. My question is, if I dropped the cradles out with the entire drive train assembly including all the steering and suspention components, will the one out of the Regal just bolt into the grand prix and pretty much plug and play? I imagine the regal's PCM to have to be swapped to the GP too? Any info on this would be appreciated! thanks!
    2010 Tahoe LT (black) | 2003 Silverado LT (blue) | 2001 Grand Prix GTP (blue) SOLD | 1997 Grand Prix SE (red) | 1995 T-bird Supercoupe (pearl white) | 1994 T-bird Supercoupe (black) | 1994 T-bird Supercoupe (blue)
  2. #2 Re: W-body engine/tranny/cradle swap
    Mar 2012
    NC
    You are exactly correct.
  3. #3 Re: W-body engine/tranny/cradle swap
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    i dont see why not.. but im not sure.. the motor mounts may be different.. im not sure as i said tho
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  4. #4 Re: W-body engine/tranny/cradle swap
    fargo, nd
    ok I just wanted to make sure, I didn't know if they changed the mounting points on the cradle a little bit so it wouldn't line up...the upper mounts should swap over too i imagine, but again thats why I was asking in case it's a little different.
  5. #5 Re: W-body engine/tranny/cradle swap
  6. #6 Re: W-body engine/tranny/cradle swap
    dont know if the regal pcm will work with the GP you may need to tune your pcm and use all of your original wire harness but add to it/ change some plugs over like the injector plugs.
  7. #7 Re: W-body engine/tranny/cradle swap
    Only thing I'd say here is ...
    Use your car's original wiring harness and pcm. Subframes are interchangeable. My Regal is wearing a Monte aluminum subframe and the GP also can use that same subframe.
    Engine, trans, axles.. it's all the same under there. The Regal rack may be a little loose feeling compared to the GP. But..it'll work.
  1. Installing new Tranny and Engine Mounts w/ Vinnie's cradle spacers
    By GeddyLee in forum Brakes/Suspension/Chassis
    Last Post: 10-31-2016, 08:20 PM
  2. Engine swap now tranny won't shift
    By chrisLB in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-24-2012, 01:27 PM
  3. need help!! with engine/tranny swap
    By Craig Ronshausen in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-14-2012, 06:49 AM
  4. 1999 Pontiac Engine And Tranny Swap
    By PGT in forum General Tech Discussion
    Last Post: 10-01-2009, 10:04 AM
  5. Help!! Tranny Swap Engine ''Refresh''
    By TDCRacing in forum General Tech Discussion
    Last Post: 06-10-2008, 12:04 PM
