Thread: replace this and that....and still wont start.
Results 1 to 20 of 21
  1. #1 replace this and that....and still wont start.
    SE Level Member LORD's Avatar
    Sep 2012
    SO CAL
    Hows it going fellas....wondering if anyone can give me a little help here.
    I have a 1998 GTP that began to have bad sputtering while driving. After a few weeks of driving it in that condition it just died on me, the RPM gauge was acting up too. Pulled over and it started back up with no issues. Now its not starting at all !! I just replaced the spark plugs ,coils back to stock (had msd's on), fuel pump, crank position sensor (cps) and the knock sensor but still it wont start. What else should do ?? Any help/tips will be much appreciated !
  2. #2 Re: replace this and that....and still wont start.
    Well, do you have spark and fuel?
  3. #3 Re: replace this and that....and still wont start.
    Sep 2012
    SO CAL
    Hmmmm....good question. I think i do. There is 1/2 a tank in it and there is fuel pressure. Well and spark....i dont know, how can i check that ? Sorry not tooo familiar with certain things yet. Im always willing to learn and getttin dirty !! Especially for my bby. (my car)
  4. #4 Re: replace this and that....and still wont start.
    You can spray a bit of starter fluid into your into to verify if it may be a fueling issue...have someone spray it while you try to start it. Did you check your fuses? Mainly the fuel pump fuse.
    04 Comp G.
  5. #5 Re: replace this and that....and still wont start.
    Sep 2011
    Logansport, IN
    Quote Originally Posted by LORD View Post
    Spark is easy to check. Pull a plug wire and plug, hold the plug up and have someone crank it over a little, if you see spark in your plug, you should be good. but DO NOT touch the end of the plug while it is being cranked over.....it is not a pleasant feeling
  6. #6 Re: replace this and that....and still wont start.
    May 2012
    Ohio
    Quote Originally Posted by rcdino1978 View Post
    Should I ask if you figured that out all by yourself? Ever tried whizzing on an electric fence? (I'm kidding, please don't take offense, I just chuckled when I saw your comment!)
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Check your fuel pump resistor. Just jump the wires together
    Sent from my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  8. #8 Re: replace this and that....and still wont start.
    you can take one wire off the coil pack, hold the wire close the coil while someone else cranks the engine, look for sparks to be jumping from coil to plug wire.
  9. #9 Re: replace this and that....and still wont start.
    I can't believe you changed all those parts and never even checked fuel and spark.
  10. #10 Re: replace this and that....and still wont start.
    GT Level Member bsharpminor's Avatar
    Mar 2012
    Minnesota
    If you find out if you have spark... in my 'bonnie over the last 175,000 miles I've replaced the ignition module twice; just a thought. The bonnie also did the same thing, stopped on me, then cooled off a bit and started back up. Did a few times like that, then it didn't want to start at all.
  11. #11 Re: replace this and that....and still wont start.
    Sep 2012
    SO CAL
    i did check for fuel just didnt know how to check for spark....i had a "mechanic" come over to work on it and well he said i needed to replace those parts. in the end it still didnt start.
  12. #12 Re: replace this and that....and still wont start.
    Sep 2012
    SO CAL
    Well i just had another Mechanic check out my GP, it seems to me that this guy knew what he was doing. The other guy assured me that it would be fixed after replacing the CPS, but he was wrong ! The new Mechanic tells me to replace the Ignition Module ( is that the thing underneath the ignition coils ? ) Its running and all but it runs like CRAPP !!! It sputters when it reaches 4K rpm's in a complete stop and it does not take off like it did before. What else should i be concerned about fellas ??
  13. #13 Re: replace this and that....and still wont start.
    you can take the icm, out and have it tested, but most of the time the test says good when its bad. jy's are the best place short of new to get another one. also make sure the ground wire is bolted on and the wire is good. its a single black wire bolted to the side of the head under the icm.
    and on the bottom is a strip of wires, its bolted on in the middle of the plug, 7 mm i think.
  14. #14 Re: replace this and that....and still wont start.
    Sep 2012
    SO CAL
    you were right scotty, i took the ICM to get tested and they said its working. I went ahead and ordered it anyway. Would the ICM be the cause of the sputtering and loss of power ? I cant drive it like i stole it anymore !!
  15. #15 Re: replace this and that....and still wont start.
    yes it can. the icm powers the coils.
    and its like the only thing you haven't changed lol
  16. #16 Re: replace this and that....and still wont start.
    Feb 2009
    flintnasty MI
    all it takes is 1 bad plug or plug wire to cause sputtering like that.
    Ohio
    He's right ^^.. It's possible you have a cracked plug... Maybe
  18. #18 Re: replace this and that....and still wont start.
    Sep 2011
    Logansport, IN
    Quote Originally Posted by rynotheman View Post
    Had someone a little to eager helping me one time, he cranked it while i had the end of the plug wire in my hand....almost shot him
  19. #19 Re: replace this and that....and still wont start.
    Sep 2012
    SO CAL
    Well fellas.....my ride is running and all but still running like crapppp !!! Ive replaced the spark plugs and double checked the plug wires. I also took the coils to get checked and they are fine. dont know what else to do ! Any more suggestions ?
  20. #20 Re: replace this and that....and still wont start.
    GT Level Member JaredR215's Avatar
    Jul 2011
    Cheyenne
    Possibly check out your MAF. Mine went out and the car would barely start and just sputter. Unplug the sensor and see if it will start.
    K&N Cold Air, ZZP Wires, ZZP 3" with hi-flo, Catback, ZZP 1.0 PCM., 180*, AL605's, 3.5 MPSStill fighting KR
  1. car wont start
    By bmx6454 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-11-2012, 09:45 AM
  2. 98 GTP wont start?
    By Al450ER in forum General Tech Discussion
    Last Post: 05-11-2011, 08:02 PM
  3. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  4. Car wont start
    By jluca in forum General Tech Discussion
    Last Post: 12-01-2010, 08:37 PM
  5. Car wont start help please.
    By GMCARS4LIFE in forum General Tech Discussion
    Last Post: 09-07-2010, 10:23 PM
