Thread: Please Help!
Results 1 to 11 of 11
  1. #1 Please Help!
    Donating Users str3etgl0w's Avatar
    Jun 2011
    Saginaw Mi
    ok so I just put a motor in 02 impala and have never had this happen before, when you start it up it runs good for a few seconds somtimes longer then it will start bucking chugging then stalls it will fire right back up and then the same thing happens. If i unplug the maf it will stay running idles up and down a little but no stalling or bucking I have replaced the maf 3 times! I have replaced all the sensors on the TB I have even replaced the TB! I get no check engine light so my scan tool dont tell me much anyways please I need some help i have been messing with this car a few days and am getting frusteradted
    here is a link to my youtube video showing what the car is doing
    http://www.youtube.com/watch?v=Y_5dLtLAigw
    things I have done
    Replaced TB
    Sensor
    Coils and icm
    new plenum and Map sesnor
    2002 GT, L67 Swap, Tuned, Headers, 3.5 pulley,CAI, 3.29 Gears,
    "I was banging 7 gram rocks that's how I roll, Winning I have one gear GO! Epic Winning"
  2. #2 Re: Please Help!
    Aug 2011
    'Merica
    vid is private on my end
  3. #3 Re: Please Help!
    Jun 2011
    Saginaw Mi
    ok should be public now
  4. #4 Re: Please Help!
    Denver
    sounds like you're running out of gas. Have you checked fuel pressure etc?
  5. #5 Re: Please Help!
    Double check the maf connector for voltage etc. You won't get codes if it doesn't run long. Another thing is to check for vacuum leaks.
  6. #6 Re: Please Help!
    Jun 2011
    Saginaw Mi
    Got gas , I can't find any vacume leaks
  7. #7 Re: Please Help!
    Denver
    I didn't mean you were literally running out of gas. I mean - maybe your FPR is messed up or your your fuel pump.
  8. #8 Re: Please Help!
    Jun 2011
    Saginaw Mi
    Lol I don't have a gauge to messaure it but do you think that would make it run fine with the maf unpluged
  9. #9 Re: Please Help!
    Sep 2012
    Columbus OH
    Unplugging the MAF makes the car run off speed density, using primarily the MAP sensor. If you unplug the MAF, and it runs, there's your problem. If the MAF is messed up, the computer takes those incorrect signals over everything else. Take away the false signals, the computer switches to "back up" mode. My Park Ave has been running off speed density for a while now after the MAF went out suddenly. Another thing you could try is get a fuel pressure gauge, which aren't expensive and are very handy to have. That would tell you how much, if any, fuel pressure you're getting. Pump could be dying, providing just enough prime to start the engine but not supply it. I'd also test the relay with a 9 volt, just to eliminate that as a cause.
  10. #10 Re: Please Help!
    Jun 2011
    Saginaw Mi
    See I am wondering if its the wiring to the maf somewhere cause yes it runs fine other then ideling a little high at times when the maf is unplugged but I have tried replacing the maf 3 times and it still does it when its plugged in
  11. #11 Re: Please Help!
    Scottydoggs can tell you about connectors/wiring getting cooked over the exhaust manifold.
