Thread: Power steering pressure hose
Results 1 to 17 of 17
  1. #1 Power steering pressure hose
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    Been awhile since I've been on fellas but I'm needing some help. Any help on how to swap out the power steering pressure hose would be great. Even a link to another thread if ya got one. It's looonnng over due and since the wife just got another new car figure better give this one a little love. Would deffinetly take any pointers looks like the subframe has gotta drop but how far what to watch out for when doing it ect. I only have a jack no lift so it will be fun. Hopefully there's a ok writeup as this is common I hear. Ok thanks as usual
    1998 GS with Open cone, PLOG, ZZP Catless DP, tune & Intense MPS 3.6. Pulls good enough to make the woman smack me and call me a D!*k.
  2. #2 Re: Power steering pressure hose
    the only real way to get to the lines from the rack is from under the car d/s and you need a 18mm line wrench is best, not needed.
    and the one line end is hose clamped onto the pump the other is a bolted line to the pump, the lines themselves are just clipped into place, they pop right out.
  3. #3 Re: Power steering pressure hose
    Oct 2008
    IL
    Ok so let me get this right. 18mm on driver side of rack no need to drop subframe (I got girly hands)and here's where I need to clear it up with you where it connects to the power steering pump I can get to that by taking off the passenger tire and it's not a nut? I though it was on the power steering pump with a 15 or 16 mm nut? Also how long this job take you? Thanks as usuall
  4. #4 Re: Power steering pressure hose
    Grand Rapids, MI
    Why install a new pressure line? what's wrong with yours?
  5. #5 Re: Power steering pressure hose
    at one time i changed the pump, then later i did the rack.
    pump, one line is a hose clamp, the other is a 13 mm or so, and yes pass side tire off and you can get to both lines at the pump.
    the rack side im pretty sure you dont need to drop the sub frame. but if its tight its easy to drop it a bit. the frame bolts are 18 mm as well. as the line bolts to the rack.
  6. #6 Re: Power steering pressure hose
    Oct 2008
    IL
    Quote Originally Posted by brandonl2000 View Post
    It's been leaking for a looonnngggg time now really seems to be just 100% screwed.
  7. #7 Re: Power steering pressure hose
    your sure its the lines? not the rack or the pump its self?
  8. #8 Re: Power steering pressure hose
    Oct 2008
    IL
    Yea I had it checked out to double check my guess. How bad is replacing the rack a whole new beast I bet.
  9. #9 Re: Power steering pressure hose
    its not the worst job to do.
    i did mine took 4 hours from start to finish, like car on the ground and tools cleaned and put away done.
    and i did it alone for 99% of the job, had a friend wiggle the steering wheel to get the shaft back on the rack.
    i also backed up on a set of ramps, then jacked the front up and used jack stand for the front, you get a few more inches of room that way. for you and the next 3 hours or so.
  10. #10 Re: Power steering pressure hose
    Oct 2008
    IL
    Well good to know not a HUGE challenge. Im gong to hopfully knock that hose out of the way before it gets cold. Thanks for the pointers as usual Scotty you always chime in for a fellow GS lol
  11. #11 Re: Power steering pressure hose
    you got it. GS for life lol lets hope not lol
  12. #12 Re: Power steering pressure hose
    Oct 2008
    IL
    I just picked up some Bullitts for my GS actually just need to cover up the stupid mustang center made me fall in love all over. Gotta clean them up and paintem. I could rock a GS for yearsssss if they kept making them look exatly the same lol.
  13. #13 Re: Power steering pressure hose
    i had no love for my stock wheels. and they leaked, the sts wheels work for me at this point, price was right, and they hold air.
    post some pics when you get yours bolted on. i don't think i've seen them on a regal yet.
  14. #14 Re: Power steering pressure hose
    Oct 2008
    IL
    I got them on right now. Been on for about a week. Rocking some snow tires but better than my stockers that where leaking and tires dry rotted and wasnt about to chance buying new tires that would leak anyway. Im going to doing a just plain silver on them. Got a hell of a deal on them
  15. #15 Re: Power steering pressure hose
    Oct 2008
    IL
    Here ya go. Not sure if Im going with a plain ole silver or more on the titanium side but I HATE polished lip rims so this is a must.
    Uploaded with ImageShack.us
  16. #16 Re: Power steering pressure hose
    man i love green. both my new trucks were green.
    they look pretty good. i agree about the lip as well.
    no window tint yet? that would make it all pop a bit more.
    and the spoiler fixes up the ass of these car, its lacking if i do say so myself.
  17. #17 Re: Power steering pressure hose
    Oct 2008
    IL
    Oh I tried to tint it I had a shop do it 3 times but kept screwing it up till I finally snapped had them rip it off at 1 in the morning when they still wernt done the 3rd time. I bought all the "tools" to do it myself but just no time work 3 yearold... WIFE lol. I will hopfully give tinting a shot myself but as for now I went through hell trying to get it tinted so I gave up on that. I need to clean up the headlights clear the corner and rock that look for a bit but tints are a HIGH priority when I have the nerve for it again. I like them best deal I could find and I needed new wheels fast I was adding air 3 times a day in one tire
  1. Anyone got a write up one Power Steering pressure hose
    By chevyy1212 in forum General Tech Discussion
    Last Post: 02-20-2012, 08:18 PM
  2. Power steering high pressure line 04+
    By Javi in forum Brakes/Suspension/Chassis
    Last Post: 10-15-2011, 09:37 AM
  3. 2002 Grand Prix power steering hose replacement.
    By ktom6 in forum General Tech Discussion
    Last Post: 06-29-2011, 10:31 PM
  4. How to replace Power Steering Hose
    By webxfx in forum 3.4L V6 (LQ1) DOHC
    Last Post: 12-09-2010, 07:56 AM
  5. power steering air pressure.
    By Teardrop in forum General Tech Discussion
    Last Post: 09-18-2010, 08:44 PM
