Thread: New Knock Retard
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21 Re: New Knock Retard
    Pennsylvania
    Boom booms?
    It's an industry term.
    Dec 2010
    DMV
    Tuned maf? On the PCM? Maf tables?
  3. #23 Re: New Knock Retard
    GT Level Member kissmyss's Avatar
    Jan 2009
    ny
    Well after a little more digging if found that my ltft's are at 7.6 at wot. Iirc fuel trims should lock in at close to 0 as possible. Think I found my culprit. Real question is why. Why just out the blue?
    My fuel trims change depending on how much gas is in the tank as well, but always lock at 0 when going full throttle. I only get some kr during full throttle, with Bp. I used to work at a gas station and there are different factors involved when buying. Did the filling truck just leave before you got there, which mixing the crude on the bottom of the tank with the gas as it fills. Is the tank low on gas, which causes you to get some crude with your gas. Did the station check for water in the tank, which could mix with your gas. Is the station mixing the low grade with the high, to make more money. You get the point, Consumer affairs, which regulates station don't have enough personnel to check often enough and usually only comes around when they get numerous complaints. I usually throw some Seafoam in the tank once a year and keep some Torco race fuel concentrate in the trunk for those bad gas days. When I have Kr, the Torco always eliminates it. I wish Sunoco still made 94 octane, because that's what I would be using.
    05 SS CAI intake, Front & rear STB's, ZZP SS DP wcat, ZZP 180 t-stat, ZZP 3.5 tensioner pulley (both), ZZP S/S ceramic plog with ceramic crossover, Overkill Pcm, Aeroforce triple gauge w/pillar pod, Thrasher 3.4 s/c pulley, MCR 200 amp alternator, PRJ wires, Intense Shift kit, ZZP 1.9 modded rockers, ZZP stage 2 Tb, Extreme Dimensions rear bumper lip.
  4. #24 Re: New Knock Retard
    they still do, thats what I run.
  5. #25 Re: New Knock Retard
    Jan 2009
    ny
    It's hard to find Sunoco in my area, the ones that are close don't sell 94 and the attendants said the 94 was phased out. I was told it didn't sell well over 93, I guess it's an individual station thing.
  6. #26 Re: New Knock Retard
    Petro Canada bought them, probably why you can't get it down there.
  7. #27 Re: New Knock Retard
    Get thsoe fuel trims locked/dialed in.
    Change in temperature always screws with sh1t.
    Hence why I told ya to just leave the 3.5" and re-tune it back when you first started asking all your questions a month or so ago.
    Then again, I probably told you toss the 3.4" on it and not care because engines are like a hundred bucks on CL...lol.
    If you are needing a custom tune...this would be an ample time to hog out the blower and the TB just for shenanigans since it is getting tuned from scratch anyways...right? Buy a Wideband too?
    Weeeeeeeeeeeeeeeeeee, then just run the 3.4" at that point...should be easily tunable.
  1. knock retard
    By RideWithPride in forum General Grand Prix Discussion
    Last Post: 08-19-2012, 11:41 AM
  2. 5* of knock retard at WOT please help
    By asite57 in forum General Tech Discussion
    Last Post: 06-15-2012, 08:45 PM
  3. Knock retard on a NA
    By Ophidia in forum General Tech Discussion
    Last Post: 02-22-2012, 11:10 PM
  4. Knock Retard
    By SJAndrew in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2010, 01:05 AM
  5. Knock retard question...
    By a98gtp4u in forum Introductions/Noob Questions
    Last Post: 09-08-2009, 05:10 PM
