Thread: gtp running problems
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #1 Re: gtp running problems
    SE Level Member Special K's Avatar
    Aug 2012
    Western NC
    Yes i understand that. I have time now and leave for work very early in the morning. Iwouldnt use the other cleaners anyway. Just wonering why not duster. Is it not electrical component cleaner? Is a maf sensor not a electrical component? Just asking hypothetically anyway, as in i dont have any.
  2. #2 Re: gtp running problems
    You can use electrical parts cleaner
  3. #3 Re: gtp running problems
    Did you say Seafoam fixed a vacuum leak/LB1?
  4. #4 Re: gtp running problems
    Aug 2012
    Western NC
    Yeah it fixed LB1 code. A friend told me if i used seafoam it would balance out the fuel to air ratio. First time i started up after driving it home the ses light was off and hasnt been on since
  5. #5 Re: gtp running problems
    Aug 2012
    Western NC
    Got down to the real source of the problem today. Looked around for the vacuum leak found that the egr was sucking in air. Put some silicone and fixed that. Cleaned MAF sensor. The took off the throttle body to clean and it was bad. But thats not the worst thing in the TB there was coolant. Errrr guess i got a bad intake gasket. Funny thing is past owner said he just replaced it. Better than a head gasket atleast
  6. #6 Re: gtp running problems
    That's good...I wasn't buying the Seafoam magic. It takes 3 consecutive start cycles for the light to go out.
  1. problems with car running
    By jdb1601 in forum Introductions/Noob Questions
    Last Post: 04-13-2012, 11:11 AM
  2. GTP Running Rough.. few new parts but still not running right.. HELP
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2010, 02:34 PM
  3. 1993 3.1 running problems could be trans
    By ronaldgtp in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 10-28-2009, 08:16 PM
  4. problems with car running
    By dsanchz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-10-2009, 02:02 AM
  5. Starting/running problems
    By 04gpgt2 in forum General Tech Discussion
    Last Post: 10-21-2008, 09:29 PM
