Thread: Fog Lamp Problems
Results 1 to 3 of 3
  1. #1 Fog Lamp Problems
    Bloomington, IL
    so the other day i realized that the fog lamps crapped out on me. The only problem is, there's no way the lamps are bad. I checked the fuse and it was fine because that was my first instinct. I even put a replacement fuse in to check it, and still nothing happened. I have a feeling that the switch is bad...has anyone had problems with this before or know anything about it?? I really have no idea how to go about getting to see if that is real issue. FYI, i dont know jack about electrical. I havent checked the lamps as that will be a grand ol' time knowing that I will get to jack up my lowered GP...if you know anything PLEASE let me know!!!
  2. #2 Re: Fog Lamp Problems
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    The first thing I would do is grab a multi-meter and check for voltage at the bulb connector on the fog lamp. Then you can work your way back up the system from there.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  3. #3 Re: Fog Lamp Problems
    Oklahoma
    Moved this to the correct section as the Tech Tips (where this was located) is for:
    "post your shortcut ideas, things that make a job easier."
  1. A/c Problems
    By TripleZero in forum General Tech Discussion
    Last Post: 08-12-2010, 10:57 AM
  2. Auto Lamp Replacement Guide (Bulb Numbers)[*]
    By LowlyfeGTP in forum How To Write-Ups/Tech Tips
    Last Post: 07-19-2010, 07:56 AM
  3. Before I have problems...
    By Keet04GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-25-2008, 08:22 AM
  4. cam problems
    By boredout in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-05-2008, 06:59 PM
