Thread: Wiper Transmission?
Results 1 to 17 of 17
  1. #1 Wiper Transmission?
    Apr 2012
    Windsor
    Hey
    So my wipers stopped working, They would'nt move at all so i tried taking it apart to see if i could find an issue. Nothing, so i figured the wiper motor is done, So i pulled a motor from a junker and took it to a shop to install. They installed the motor and said the wipers wont park and ill have to buy a new wiper transmission. They said $450 with install, WTH are they talking about? is there an easy fix to this?
    2005 grand prix gtp
  2. #2 Re: Wiper Transmission?
    Ohio
    04 05 GRAND PRIX WIPER TRANSMISSION on eBay!
    do it yourself...if you can turn a wrench, you can replace it
  3. #3 Re: Wiper Transmission?
    Or..you could read up on the tab that usually causes the parking issue. I can't think of a recent thread..but with winter coming..it's common.
  4. #4 Re: Wiper Transmission?
    theres a tab you need to bend back, ice bends the tab back and then they work but wont park in the down position.
    theres a how to here somewhere.
  5. #5 Re: Wiper Transmission?
    Apr 2012
    Windsor
    Ya i remember reading about some metal tab thing, That applies for my year of car as well?
  6. #6 Re: Wiper Transmission?
    bill ninja'ed me lol
  7. #7 Re: Wiper Transmission?
    Maybe..lol
    In before the Scotty!
  8. #8 Re: Wiper Transmission?
    Ohio
    Maybe..lol
    lol the scotty
  9. #9 Re: Wiper Transmission?
    Apr 2012
    Windsor
    K just got the car back, The guy on the phone was wrong apparently, Its not that the wipers wont park, They still dont move at all, The mechanic i spoke with said the pivot points on the wiper transmission are all seized, Because the pivots are steel and the shafts are aluminum it causes the metal to oxidize and turns into an almost lock-tight seal on the pivot points. So he said replacing it is the only way to fix it. Ever hear of this before?
  10. #10 Re: Wiper Transmission?
    ive never done on on a w body, but have in lots of other cars and trucks, its not that hard to change in most cases.
    the part where the wiper arms bolt on has to come off and then sometimes a center mount point and bolted to the motor it self. all the plastic cowl needs to be removed to get to it. fairly easy to change.
    you may even be able to take yours out, spray the moving joint with penetrating oil and work the parts by hand to free them up.
  11. #11 Re: Wiper Transmission?
    Uh.. I supposed it's possible (disregard that Scott posted before me, I'll delete his post so I'm ahead of him again) Guess that means he tested the motor and it's good..but the trans is bad..odd.
  12. #12 Re: Wiper Transmission?
    delete me lol
    i must say ive never seen a wiper trans seize up,( the motor yes) they always break somewhere.
  13. #13 Re: Wiper Transmission?
    I'm agreeing with Scotty.. Never seen them seize. I know dodge ones used to pop apart at the link points..but... nothing else.
  14. #14 Re: Wiper Transmission?
    I'd probably roll on over to the shop to have him show me that they are seized.
  15. #15 Re: Wiper Transmission?
    Apr 2012
    Windsor
    is there a write up or how to floating around here? i cant find one. So far im having issues just getting this cowl off....
  16. #16 Re: Wiper Transmission?
    this thread shows how the cowl is clipped on,http://www.grandprixforums.net/water...-fix-6961.html the driver side you need to take the wiper arms off first. you pop the caps off, under the cap is a nut, take that off, now you need to pop the arm off, they are on a tapered shaft. i used a hammer and used the claw side to pop it up, do this away from the windshield as it can and will break. be careful.
  17. #17 Re: Wiper Transmission?
    Apr 2012
    Windsor
    *update*
    So i pulled out the whole assembly, The Wiper transmission was seized, The pivot point on the passenger side was sealed in rust, even in a vice i could not get it to move. I soaked it in CLR overnight, Took it apart, Greased it and put it back together, Moves freely. So if your wipers are not working and you dont think its the motor, Pull the transmission out and try to move it. As far as difficulty goes i would say its easier than changing brake pads and i have no idea why i took it to a shop to replace the motor . I could seriously put a new wiper motor in that car in under 30 min.
  1. 02 Wiper Problem and many more
    By airjordan223 in forum General Tech Discussion
    Last Post: 06-24-2010, 01:14 PM
  2. Wiper problems... help i cant see
    By squeaks130 in forum General Tech Discussion
    Last Post: 12-29-2009, 09:40 PM
  3. Wiper issue
    By White Sunshine in forum General Tech Discussion
    Last Post: 12-23-2009, 03:11 PM
  4. winshield wiper help
    By RedLedbetter in forum General Tech Discussion
    Last Post: 04-07-2009, 06:48 PM
  5. Where do you buy new wiper arm?
    By 98gpgt98 in forum General Tech Discussion
    Last Post: 06-11-2008, 08:04 PM
