Thread: gas gauge and DIC miles not accurate
Results 1 to 8 of 8
  1. #1 gas gauge and DIC miles not accurate
    Jun 2012
    Seattle, Washington, United States
    the amount of miles remaining on my dic and the gasoline gauge on mine and my dad's pontiac isn't acurate. it goes up and down a lot. especially when I'm below the half way mark on gas. anyone else have this problem? and if so, any solutions?
  2. #2 Re: gas gauge and DIC miles not accurate
    Probably need a new fuel sender. It's in the tank.
  3. #3 Re: gas gauge and DIC miles not accurate
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    if its original then you might need a new sending unit they go bad in these cars but you cant expect the DIC or gas gauge to be spot on its just a general guide line
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
    SE Level Member gotgtp's Avatar
    Chicago, IL
    I'm not positive but don't almost all gm cars have (what I'm going to call a floating needle)? Both of my gp's and my moms ga gas gauge move a lot. Especially under half tank.
    2004 Comp G - Bone Stock except visual mods
  5. #5 Re: gas gauge and DIC miles not accurate
    Oct 2011
    Michigan
    yes they do (at least w bodies do) and the sensors on the floating part of it wear out which can cause more extream changes in the needle on his gas gauge
  6. #6 Re: gas gauge and DIC miles not accurate
    Jun 2012
    thanks
    and i will look online about installing the fuel sensor. idk anything about that. about how much do they cost and is it better to get it from o'reilly/another auto store or online?
  7. #7 Re: gas gauge and DIC miles not accurate
    You can get one from ebay for like $20
  8. #8 Re: gas gauge and DIC miles not accurate
    GT Level Member djrepoman's Avatar
    columbus ohio (polaris)
    dorman part #911-008 23$ shipped rock auto
    2000 GT ,E85 powered, and still slow
    98 GTP Stock
  1. Non accurate gas gauge after fuel sending unit replacement
    By ST0NGE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-04-2012, 04:22 PM
  2. Fuel Gauge Not Accurate
    By Connors33 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-02-2009, 09:07 PM
  3. Replies: 0
    Last Post: 10-28-2009, 09:42 AM
  4. Is the temperature gauge accurate?
    By Summit670 in forum General Tech Discussion
    Last Post: 12-22-2008, 12:07 AM
