Thread: Common Acronyms
Results 21 to 40 of 46
Threaded View
  1. #1 Common Acronyms
    GTP Level Member TyroElite's Avatar
    Williamsport, PA
    This is a place to post up commonly used accronyms in the w-body world. Please feel free to add to this list with your own additions. Soon, we should have a permalink that gets updated. Here are a few to get started:
    ABDC - After Bottom Dead Center
    A/C - Air Conditioning
    ACC - A/C Clutch
    A/F - Air/Fuel
    AFC - Air Fuel Controller
    AFR - Air/Fuel Ratio
    AE - Acceleration Enrichment
    ALT - Alternator
    AP - Air Pump
    ATDC - After top dead center
    BBDC - Before Bottom Dead Center
    BCM - Body Control Module
    BDC - Bottom Dead Center
    BTDC - Before top dead center
    BTSI - Brake Transmission Shift Interlock
    CAI- Cold Air Intake
    Cat - Catalytic converter
    CKP - Crankshaft Position Sensor
    CPS - Cycles Per Second (Cycles per second are taken of the crankshaft position sensor)
    DEG - Degrees Celsius or Fahrenheit
    DIC - Driver Information Center
    DTC - Diagnostic Trouble Codes
    DP - Down Pipe
    ECT - Engine Cooling Temperature
    EFI - Electronic Fuel Injection
    EGR - Exhaust Gas Recirculator
    EGT - Exhaust Gas Temperature
    EST - Electronic Spark Timing
    FI - Fuel Injection
    FPR - Fuel Pressure Regulator
    FT - Foot
    FTL - For the Loser
    FTMFW - For the Mother F**kin Winner
    FTW - For the Winner
    FWI - Fenderwell Intake
    GPF - Grand Prix Forums
    HAI- Hot Air Intake
    HZ - Hertz (Frequency)
    IAC - Idle Air Control
    IAT - Idle Air Temperature
    IC - Intercool(er/ed)
    ISS - Idle Speed Stepper
    KOEO - Key On Engine Off
    KOER - Key On Engine Running
    KPA - Kilopascal
    KR - Knock Retard
    L36 - Series II naturally aspirated 3.8L engine code
    L26 - Series III naturally aspirated 3.8L engine code
    L67 - Series II Supercharged 3.8L engine code
    L32 - Series III Supercharged 3.8L engine code
    LS4 - v8 engine code
    LBS - Pounds
    LIM - Lower Intake Manifold
    MAF - Mass Air Flow
    MAP - Manifold Absolute Pressure
    MAT - Manifold Air Temp
    Mg - Milligram
    MPFI - Multi-port Fuel Injection
    MPH - Miles Per Hour
    MPS - Modular Pulley System
    Ms - Milliseconds
    NA - Naturally Aspirated
    NBO2 - Narrowband O2 Sensor
    02 - Oxygen
    PCM - Powertrain Control Module
    PCV - Positive Crankcase Ventilation
    PE - Power Enrichment
    PEM - Ported Exhaust Manifold
    PLOG - Power Log; front exhaust manifold from ZZP
    PSI - Pounds Per Square Inch
    ROFL - Rolling on the Floor Laughing
    ROTFLMAO - Roll on The Floor Laughing My Ass Off
    RPM - Revolutions Per Minute
    SC - Supercharg(er/ed)
    SEC - Seconds
    STB - Strut Tower Brace
    TB - Throttle Body
    TBI - Throttle Body Injection
    TCC - Torque Converter Control/ Torque Converter Clutch
    TCS - Torque Control System / Traction Control system
    TDC - Top dead center
    TOGS - The Other Guys headers
    TPS - Throttle Position Sensor
    T-stat - Thermostat
    UIM - Upper Intake Manifold
    VE - Volumetric Efficency
    VS, GT, XP, XPZ - aftermarket cams
    VSS - Vehicle Speed Sensor
    WBO2 - Wideband O2 Sensor
    WOT - Wide Open Throttle
  1. Common Accronyms
    By TyroElite in forum Forum Bugs/Suggestions
    Last Post: 01-03-2008, 11:31 PM
