if the whine is coming from the drivers side of the engine its your trans pump. if you haven't serviced your trans it cant hurt to do it.
if the filter is clogged it makes the pump whine, and makes the shifting feel off, hard or slipping, can go either way.
not good to drive it like that if its the trans pump whining.
It definitely sounds like it's coming from the driver's side.
Aeroforce cant read the torque of a car for beans, its impossible for it to be right.
Might want to drop the pan and change the filter.
I figured it would be closer than that though lol. Do you recommend new fluid while I'm already changing the filter? I'm also thinking about putting in a homemade shift kit while I'm at it. Heard you can make one that's equal to Thrasher's for like 10 bucks.
