Thread: what the heck does "FWI, PEM, AND EGR DELETE" MEAN?
Results 1 to 20 of 23
  1. #1 what the heck does "FWI, PEM, AND EGR DELETE" MEAN?
    Peachtree City GA
    what do these mean ive seen them as mods but don't have a clue what they mean, please be specfic, thanks
    Topeka, KS
    Fender Well Intake = FWI
    PEM = Ported Exhaust Manifolds, also known as Poor Man's Headers
    EGR Delete means you got rid of your EGR (by blocking off with a plate usually) that pumps unburned fuel and and exhaust fumes back into your intake giving you cleaner air in your intake.
    Peachtree City GA
    so how does an egr delet help u?
    Topeka, KS
    When you have an EGR it pumps exhaust into your intake thus you don't have pure 100% un burned air supply. When you delete it it shoves all the exhaust out the pipe where it belongs giving you cleaner air in your intake and helps you make more HP. On the downside when you delete it you tend to get worse gas mileage or so i've heard.
    Peachtree City GA
    is it hard to install? and how would that possibly affect the gas milage?
    SE Level Member hydro1110's Avatar
    Mechanicsville VA
    Quote Originally Posted by BLACKEDOUTGTP View Post
    Its harder to get the EGR off then it is to install the delete. The EGR delete is a block off plate that you bolt to the intake, then you will need to add the electronics. I think the electronics come as plug and play but I could be wrong. When I had mine, I spliced the wires. You can also get by without the electronics part if you have a tuner that will allow you to remove the codes for the EGR
    SE Level Member SDGrandPrixGT23's Avatar
    San Diego, California
    pics or write ups?
    Quote Originally Posted by SDGrandPrixGT23 View Post
    pics or write ups?
    For which?
    GT Level Member SD GTP's Avatar
    Kirkwood, Delaware
    Most delete the EGR system when installing headers. ZZPerformance sells small plates with block off the holes in the Intake Manifold and on the Rear Header.
    I believe I have some pictures around from after my header install that I can post up soon
    MACGP President
    3.25"/P&P Gen III/ZZP Stg II TB/Thasher CAI/ZZP VS Cam/TOG Xtremes/AL 104s/180*/Full 3" Exhaust/SD Package/GMPP Sways & Arms/DuBob'd
    Wichita, KS
    Made my own EGR block off plates from some scrap 1/4" thick aluminum.
    Many make their own with a penny and the left over clamps/mounting ends of the OEM EGR unit.
    You don't really notice that much of a gas mileage drop. Your intake stays cleaner, and cooler is the main gain. But if you have state inspections...this is a no-no-go mod to do.
    ~F~
    Peachtree City GA
    where is the egr located on the L67 and do u have to block both or just the one on the intake?
    Port Hope Ont,Canada
    Here is a website
    I think you will really like
    called WikiAnswers Q&A Community
    WikiAnswers - What size is the smallest supercharger pulley you can ...
    this site covers just about every question you will need to have a answer 4
    i will not be goingout tonight to get the SLP Headers out of storage snowing really bad here...
    and the EGR is on the drivers side top of the motor near the back
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    you can just unplug the egr electrical connector.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
    made my own with a quarter, a nickle, some rtv, and the cut off ends of the EGR hoses. nice.
    SLP Headers come with a Block off plate
    and also the wire to delete for the code...
    I have the SLP Headers here and will see about taking some pics
    of it later... i have to go over to storage to get the headers out..
    Topeka, KS
    I Believe Your Correct Sir.
    Did you ever mass produce these Jason? Anything that gets rid of weight and keeps the engine intake temp cooler is a great thing.
    GTP Level Member TyroElite's Avatar
    Williamsport, PA
    Also note... there is a new topic in the Lounge which is being compiled to include common accronyms. THese are listed but feel free to add others!
    I'm installing my SLP nex Monday 7th of Jan,
    i'll see about getting some pics and i have a sheet from SLP
    that i will copy down about the block off ect..
    1998 GTP, U-Bend Delete,Hi-Flow Cat,No Res,SLP Headers,BRISK Plugs ,180 T-Stat, 3.4 pully
    2007 GM Show and shine August 10http://www.youtube.com/v/aRh91q1jRio&rel=1
    OQCGP Clubhttp://www.youtube.com/v/j_YHmgU9ehs&rel=1
    Peachtree City GA
    haha mass produce what???
    Topeka, KS
    EGR block off plates.
  1. How about an "Other Cars" section?
    By flynn in forum Forum Bugs/Suggestions
    Last Post: 07-06-2008, 09:15 PM
  2. 7/8" chain vs GMR 1"
    By suprchrgd in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-16-2008, 11:40 AM
  3. Has anybody ever used a "Scangauge II"?
    By Grumbletron 4000 in forum Off Topic Discussion
    Last Post: 01-04-2008, 01:22 PM
  4. Pontiac GTO from "XXX State of the Union"
    By Rocket468 in forum Off Topic Discussion
    Last Post: 12-19-2007, 10:40 PM
  5. There should be a "Forum Bugs/Suggestions" section
    By syP in forum Forum Bugs/Suggestions
    Last Post: 12-13-2007, 07:48 PM
