Thread: lot of troubles
Results 1 to 2 of 2
  1. #1 lot of troubles
    Jun 2012
    Terrebonne,Quebec,Canada
    Hi to everyone first time be here here is my troubles i have a 1998 gp gprix gtp that was to much rusted so i found a 2002 gprix gtp shell and put engine,engine harness,and pcm so now there is my problem not fuel come in rail, no spark,no headlight,key get stuck in ignition and trans shifter dont want move keep lock so maybe is was not a graet idea after all lol so if someone known something about all that let me know maybe need a 2002gp gtp pcm ?
    Pascal
  2. #2 Re: lot of troubles
    sounds like the battery's unhooked.
    make sure all the grounds are hooked up, you have 3 on the bumper side of the trans bell housing, right above the starter. one trans bolt has a stud on it where the grounds connect to it with a nut.
  1. having filling troubles
    By TEK310 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-06-2012, 10:19 PM
  2. engine troubles
    By steelmatic in forum Introductions/Noob Questions
    Last Post: 05-16-2012, 06:47 PM
  3. Suspension Troubles
    By Backstage8 in forum Brakes/Suspension/Chassis
    Last Post: 10-29-2011, 09:19 AM
  4. HVAC troubles
    By ajramos26 in forum General Tech Discussion
    Last Post: 04-19-2011, 08:56 PM
  5. Need some help with amp and sub troubles
    By Thunderturd in forum Audio, Security & Visual Electronics
    Last Post: 08-20-2009, 02:51 AM
