Thread: White Exhaust
Results 1 to 11 of 11
  1. #1 White Exhaust
    GT Level Member fri3dchick3n's Avatar
    Alaska
    When I start my car up on a nice warm day I can still see white exhaust smoke coming out from the exhaust tips. It doesnt leave any white residue behind. The car seems to be driving fine. This white smoke doesnt really have me concerned too bad but would like to know whats going on?
    Anyone have any ideas?
    99 GTP: 3.4'' MPS, Overkill PCM, Intake, Catless SD Headers, TransGo Shift Kit, 180º Thermostat, Flipped Dog Bones
  2. #2 Re: White Exhaust
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    sounds like your burning oil its kind of a hit or miss type thing with 3800s out 2007 GT burned oil at 40K miles but my 1999 GTP doesnt at 176k miles
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  3. #3 Re: White Exhaust
    GT Level Member Beelzeboul's Avatar
    Racine
    they probably already replaced the LIM already on your 99 with the aluminum one it should only have to blow once before you do that and than you will get alot more life out of them
    the white smoke usually means coolant getting into engine and the usual culprit is what I had said to asite the LIM gasket tends to go out pretty early regardless of mileage just because the dexcool eats the **** out of them
    Smoke color
    Blue = Oil
    White = Coolant
    Black = Gas
    I'm sorry officer I didnt know I couldn't do that
  4. #4 Re: White Exhaust
    GTX Level Member JDrach's Avatar
    Nov 2011
    Indiana
    couldnt that mean you have a bad LIM gasket and oil/antifreeze is leaking through to the exhaust?
  5. #5 Re: White Exhaust
    Do you have a cat? If you dont its normal for your car to smoke.
  6. #6 Re: White Exhaust
    Oct 2011
    Michigan
    i would be amazed if my LIM had already been done, my buddy with a 2002 monte carlo ss just replaced his LIM and his car has white smoke coming out his tailpipes on start up i mean white and blue smoke are hard to distinguish sometimes
    Ohio
    Guys... N/A means it's not just the lim gaskets.. The UIM is the main problem.
  8. #8 Re: White Exhaust
    Oct 2011
    Michigan
    his sig says hes supercharged
    Ohio
    K, can't see a sig... I'm on tapatalk
    Ohio
    So in that case, I'd check the supercharger and tb gasket.
  11. #11 Re: White Exhaust
    Alaska
    I am Catless now since my header install.
    LIM gasket were replaced a year and a half ago so they are good but I will still check gaskets out.
  1. white residue in exhaust tips
    By cardiffGIANT98gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-19-2012, 02:32 PM
  2. Can't tell between white smoke and exhaust
    By steeck1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-12-2011, 12:05 PM
