Thread: Review my cam setup.
Results 1 to 20 of 24
  1. #1 Review my cam setup.
    May 2012
    Burlington, Wisconsin
    I just ordered a cam setup through ZZP and was wondering if I covered everything.
    I bought:
    XP Hot Cam
    105# springs
    Modified retainers
    Stock timing chain
    RTV Ultra Copper
    Timing chain dampener
    12 COMP CAMS reuseable rocker bolts
    supercharger gasket (except L36/22)
    2 coolant passage O-rings (except L36/22)
    GM oem aluminum intake gasket set
    front cover gasket
    ARP assembly lube
    valve cover gaskets
    crank bolt
    cam bolt
    pcv valve
    injector o rings
    coolant
    Is there anythingI missed or should I be golden?
    1998 GTP Sedan: Gen III, Speedy Daddy Headers, SLP Catback, Magnaflow High Flow Cat, Open Cone Intake, Autolite 104s, Debadged, more to come!
  2. #2 Re: Review my cam setup.
    Omaha, NE
    A tune
    Oil
    Coolant
    Assembly lube
    Injector O rings
    PCV Valve
    Air Filter
    Spark plugs
    Spark plug wires
  3. #3 Re: Review my cam setup.
    May 2012
    A tune
    Oil
    Coolant
    Assembly lube
    Injector O rings
    PCV Valve
    Air Filter
    Spark plugs
    Spark plug wires
    Why air filter, spark plugs, and spark plug wires?
    Quincy, Mass
    You'll want some thread sealant with PTFE, it's in a white bottle at the parts store. Use it on the lim bolts and on the timing cover bolts, and you can use it on any bolt that coolant comes out of on the block. And when you put the lim gaskets on put some rtv in the bottom corners where to gasket pieces meet.
    No more GP 04 Impala SS Indy:
    Quincy, Mass
    Quote Originally Posted by Btownmills View Post
    Because you won't usually be using the same size plug, wires might not be needed and air filter should be fine if it's a cone thats clean.
  6. #6 Re: Review my cam setup.
    Omaha, NE
    I usually break at least one of the wires getting them off.
    Its always good to have a fresh set of plugs to break in the cam with. $12 insurance.
    And Air filters are always good to replace.
  7. #7 Re: Review my cam setup.
    May 2012
    I just replaced all of them not too long ago. I think I'm going to risk it and leave them be. Also, why would I need new injector o-rings? I didn't think I needed to remove the injectors to put in the cam?
    Quincy, Mass
    To take the supercharger off you'll need to take the fuel rail off, same to get the valve covers off. You might not need new orings but it's always good to have a set on hand incase you flatted or tear one putting them back in.
  9. #9 Re: Review my cam setup.
    Omaha, NE
    Old O rings can get brittle and/ or tear in the removal/ re installation process.
    You're "supposed to" put on new o rings any time the injectors are removed.
  10. #10 Re: Review my cam setup.
    May 2012
    I'll add those to the list then. Think I could get away with not getting a new pcv valve also?
    Zzp vc gaskets leak. Thought weve covered this one enough times.
    Quincy, Mass
    The pcv is like $5
    Ohio
    Lol pcv is 2.95
  14. #14 Re: Review my cam setup.
    May 2012
    I went with Fel Pro gaskets.
  15. #15 Re: Review my cam setup.
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    i though you needed a double roller timing chain to run 105# valve springs?
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  16. #16 Re: Review my cam setup.
    no.
    Quincy, Mass
    Over 105 and you need the double.
  18. #18 Re: Review my cam setup.
    Jan 2012
    Philadelphia
    why are you using a stock timing chain?
    Quincy, Mass
    Nothing wrong with a stock timing chain. If you dampener is too far in then get a new one and a new stock chain.
  20. #20 Re: Review my cam setup.
    Oct 2011
    Michigan
    alright so i was right you SHOULD run a double roller with 105# springs
  1. After Market Stereo Review
    By apierce1289 in forum Audio, Security & Visual Electronics
    Last Post: 03-31-2011, 06:01 PM
  2. Weapon R intake 3.1L review
    By Sesleeper in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-27-2010, 10:51 AM
  3. Review: Crue Fest
    By mlambert in forum Off Topic Discussion
    Last Post: 07-07-2008, 01:29 PM
