Thread: Plugging a Vac line
Results 1 to 8 of 8
  1. #1 Plugging a Vac line
    The Boss Iceman6669's Avatar
    Jun 2011
    I have a spare vac line spot on my vac tree that i dont need/use. I need to find the most effective way to plug it closed to prevent a vac leak.
    2011 F-150 Yote powered
  2. #2 Re: Plugging a Vac line
    GT Level Member Beelzeboul's Avatar
    Racine
    fill the hole with jb weld bolt tree down and loop a line for added protection
    I'm sorry officer I didnt know I couldn't do that
  3. #3 Re: Plugging a Vac line
    Jun 2011
    I dont know where to loop the line too.. i still need the vac tree to work.. Just one of the feeds on it is no longer needed.
  4. #4 Re: Plugging a Vac line
    Can't you use vacuum caps from the parts store.
    04 Comp G.
  5. #5 Re: Plugging a Vac line
    Caps from the parts store. Get the colored ones, they last longer
  6. #6 Re: Plugging a Vac line
    Florida
    Silicone cap from the parts store. I've seen them as small as 1/16th inch. And Poker is right, the colored ones do last longer for some reason.. Black ones on my wagon got replaced twice in 4 months, switched to the colored, and they are still on there.
  7. #7 Re: Plugging a Vac line
    if the rubber cap is too small it will crack and fail.
    Rubber or silicone as far as I'm concerned.
  8. #8 Re: Plugging a Vac line
    Jun 2011
    I am going to get the 8pc. kit az sells
  1. Which Oil line is this?
    By Wakeboy1337 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-26-2011, 09:28 AM
  2. fuel line nut rusted to fuel line!!
    By Pepino in forum General Tech Discussion
    Last Post: 08-12-2010, 08:25 AM
  3. AUX / Line In ?
    By vonlupe in forum Audio, Security & Visual Electronics
    Last Post: 07-14-2010, 03:32 AM
  4. where does this vac line go?
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2010, 01:40 PM
  5. vacuum line kit for 98 gtp?
    By Liquifire in forum General Tech Discussion
    Last Post: 11-09-2009, 09:49 AM
