Thread: pass. power window fail, help pls.
Results 1 to 13 of 13
  1. #1 pass. power window fail, help pls.
    PA
    Hello All,
    Not sure where to post this so...
    I noticed the passenger side front window was down yesterday, not being an unusual occurrence, accept it did it on its own. Took the panel and barrier off and noticed the cable hanging loose. I had to force the window up. ( at least its staying up)
    I did a search in the how to, but did not find how to repair this. Can I replace the cable or do I need more than that to get it working again? Nay help would be most appreciated!
    2002, 3.8 V8, 4 door, power windows.
    Scott
    SE Level Member Peirce1970's Avatar
    Myrtle beach, S.C.
    There is a way to fix the cable. I ran across a post somewhere I will see if I can find it. You could probable get a used regulator assembly out of the bone yard for around $40. They are pretty simple to change out.
  3. #3 Re: pass. power window fail, help pls.
    theres no way to repair the cable, you need whats called a window regulator, it comes with new tracks, motor and the cable. cost about 50 on line or less used.
  4. #4 Re: pass. power window fail, help pls.
    Dec 2008
    Lawndale, CA
    Do this. You are better off replacing the entire thing.
  5. #5 Re: pass. power window fail, help pls.
    Florida
    x3 It's a pretty common problem. All 4 of mine went at different times.
    The cable tends to get kinked somewhere and pop off track, and then you'll play hell trying to get it to work right again. Easiest thing to do is to replace the whole assembly.
    Make sure to use some tape, or have someone else hold the window up while you do this, so that you can use both hands, and it doesn't fall and break inside the door.
    GT Level Member Utter99's Avatar
    Warsaw indiana
    That's what happened to mine . Easy fix just replace the regulated . Ad a 3.8 v8 eh?
    MY LUGNUTS REQUIRE MORE TOURQE THAN YOUR HONDA PUTS OUT!!!
  7. #7 Re: pass. power window fail, help pls.
    St. Louis
    Quote Originally Posted by Utter99 View Post
    What, you've never heard of the McLaren swap, lol...
  8. #8 Re: pass. power window fail, help pls.
    PA
    Thanks everyone!
    Yup Utter99, plane jane stocker. ( I meant V6, sorry! Maybe its a V12?)
    Is it a hassle to use the same motor, does after market connect right up to the old motor?
    Scott
  9. #9 Re: pass. power window fail, help pls.
    St. Louis
    You can use the stock motor if you choose. It's held onto the regualtor with 3 bolts. I'd just keep the stock motor as a spare and use the one that comes already attached to the new regulator. Once you do these enough you can get one in and done in about 20 min start to finish, lol... Yea, they tend to break often.
    BTW, lube the felt window guides w/ some greasless dry lube really well. These windows like to stick to the felt and it can cause the regulator to do exactly what you see now. Even if it doesn't "feel" like its sticking it probably is just a bit.
  10. #10 Re: pass. power window fail, help pls.
    new window regulators come ready to go, all power plug match up.
    don't bother with the motor swap, just get the whole thing new.
    you can also spray down all the cable and slides with graphite lock spray. it helps them last longer.
  11. #11 Re: pass. power window fail, help pls.
    GT Level Member fri3dchick3n's Avatar
    Alaska
    I havent rolled my driver window down in 3 years.. I think its almost time to fix this. I know it easy..
    99 GTP: 3.4'' MPS, Overkill PCM, Intake, Catless SD Headers, TransGo Shift Kit, 180ยบ Thermostat, Flipped Dog Bones
  12. #12 Re: pass. power window fail, help pls.
    PA
    Thanks everyone for the help, K appreciate it! Ordering the whole sha-bang!
    Scott
  13. #13 Re: pass. power window fail, help pls.
    GT Level Member andremike's Avatar
    Nov 2009
    chicago
    ditto on orderintg the whole thing. I ordered mine from Amazon. Rockauto is good to.. easy to replace. did mine a week ago in 20 minutes.
  1. Amp power cable pass ..08 grand prix
    By super ted in forum Audio, Security & Visual Electronics
    Last Post: 10-19-2013, 01:34 AM
  2. No power to pass. side CV axle
    By GP_Kid18 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-01-2012, 05:44 PM
  3. Replies: 2
    Last Post: 02-14-2012, 08:47 PM
  4. damn car -_-..firewall/power wire fail
    By Dragonblaze in forum Audio, Security & Visual Electronics
    Last Post: 12-20-2010, 10:17 PM
  5. pass window problem
    By wxman25 in forum General Tech Discussion
    Last Post: 06-30-2009, 03:49 PM
