Thread: P0141
Results 1 to 6 of 6
  1. #1 P0141
    May 2012
    Burlington, Wisconsin
    I went to Advanced a few weeks ago after my SES light came on. Got it scanned, got a P0141 code. Rear o2 sensor. I replaced the o2 sensor yesterday, how long would be normal for the light to go away if all is fixed? I'm guessing it wouldn't be instant.
    1998 GTP Sedan: Gen III, Speedy Daddy Headers, SLP Catback, Magnaflow High Flow Cat, Open Cone Intake, Autolite 104s, Debadged, more to come!
  2. #2 Re: P0141
    Go clear the code with a scanner.
    It can take up to 40-50 drives with the car for certain amount of time before the check engine light may go off.
  3. #3 Re: P0141
    May 2012
    Think Advanced would do that? I don't personally own a scanner.
  4. #4 Re: P0141
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    most of the time advance wont clear a code but if you know somewhere there u can get them to clear it for ya or try disconnecting the battery might do it
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  5. #5 Re: P0141
    check around for another auto parts store, they may have a scanner and you can clear the codes then.
  6. #6 Re: P0141
    Tell them you bought (from them) and changed the sensor. They should clear it.
  1. p0141/o2 sensor questions
    By Jakegday in forum General Tech Discussion
    Last Post: 08-14-2011, 08:29 PM
  2. P0141 p0341 p1351
    By jkwidener in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-25-2011, 08:22 PM
  3. p0141 im stumped..
    By Joe m in forum General Tech Discussion
    Last Post: 01-30-2010, 12:19 PM
  4. Code P0141 ???
    By BDEGhost in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-23-2009, 01:18 PM
  5. Need help! p0141 code.
    By rcweldon988 in forum General Tech Discussion
    Last Post: 03-05-2009, 10:22 PM
