Thread: heated seat switch help
Results 1 to 5 of 5
  1. #1 heated seat switch help
    Feb 2010
    TN
    Putting 05 heated leathers in a 97 GT does anyone know if this switch will work is it as simple as they say in the diagram?
    Universal Heated Seat Switch 1ea "3 Way LED Switch" | eBay
    Thanks in advance
    Logan
    Quincy, Mass
    Yes it should work but there will be now high and low setting only on and off and there wont be a stop point as to how hot the seats get, you have to shut it off when your butt gets hot. The 04+ seats use the bcm to control the temp while 97-03 uses a sensor in the wiring harness inside the seats. On order to get the 04+ seats to have hi and low and temp you will need to take the wiring harness out of a 97-03 heated seat and put it in each 04+ seat.
    No more GP 04 Impala SS Indy:
  3. #3 Re: heated seat switch help
    Feb 2010
    TN
    Thanks swiggles that's what I was wondering about the high low feature a you were a big help. . .as usual
    Logan
    Quincy, Mass
    No problem! I myself have to get off my a$$ and fix my heated seats, drivers side never worked it has a bad element. And I want to get the harnesses to put in the seats.
  5. #5 Re: heated seat switch help
    Feb 2010
    TN
    Hey swiggles do you mean just the wiring for that attaches to the seat or the whole harness that goes under the floor?
  1. how to fix a heated seat.
    By BillBoost37 in forum How To Write-Ups/Tech Tips
    Last Post: 11-17-2019, 06:18 PM
  2. Heated Seat Switch
    By Iceman6669 in forum General Tech Discussion
    Last Post: 04-14-2012, 10:20 AM
  3. Heated Seat Switch Illumination
    By SliceTheRice in forum General Tech Discussion
    Last Post: 05-10-2010, 11:49 AM
  4. Heated Seat
    By Rather B Blown in forum General Tech Discussion
    Last Post: 12-29-2008, 01:46 AM
