Thread: Replacing AC components
Results 1 to 12 of 12
vertebrate Replacing AC components 07-16-2012, 04:05 PM
lrscgod Re: Replacing AC components 07-16-2012, 04:06 PM
tc300 Re: Replacing AC components 07-16-2012, 05:36 PM
Fivefingerdeathpunch Re: Replacing AC components 07-16-2012, 09:34 PM
tc300 Re: Replacing AC components 07-17-2012, 01:32 PM
TheOtherNick Re: Replacing AC components 07-16-2012, 09:41 PM
BillBoost37 Re: Replacing AC components 07-17-2012, 01:37 PM
Storm Smith Re: Replacing AC components 07-17-2012, 11:50 PM
Swiggles Make sure you have the good... 07-18-2012, 09:22 PM
vertebrate Re: Replacing AC components 07-19-2012, 09:36 AM
Storm Smith Re: Replacing AC components 08-29-2012, 03:07 PM
vertebrate Re: Replacing AC components 08-30-2012, 11:06 AM
  1. #1 Replacing AC components
    May 2008
    My 2000 GTP compressor is making a ton of noise when both on and off, and I have no cold air. It will stay cool for a week if I put a can of refrigerant in there, and then fade back to hot.
    I have a new compressor, accumulator, and orifice tube on the way and need to know if there's anything else I should replace at the same time? The compressor indicates that it comes with the seals and rings. Any other seals or o-rings I might need?
    Also with regards to flushing. Since it hasn't locked up, do I need to flush before installing or should I be okay with just doing a flush after all the new components are in place?
    Thanks,
    Steve
  2. #2 Re: Replacing AC components
    GT Level Member lrscgod's Avatar
    Shellman Bluff, GA
    Flush it before you install the new stuff, it's worth the cost versus putting all the new stuff on and having some crap in the condenser that causes you problems later.
    4 out of 3 people have trouble with fractions
  3. #3 Re: Replacing AC components
    GTP Level Member
    springfield IL
    Can u use water to flush the condenser..?? I got a use one awhile back and water was use to flush it before installing it
  4. #4 Re: Replacing AC components
    No, never use water.
    Its best to use a real AC machine to suck out all the freon, then do the work, then have it tested again to make sure it can hold the vacuum, then recharge qith 1.88 lbs
  5. #5 Re: Replacing AC components
    GTP Level Member
    springfield IL
    It was already out of the car... Was at a junk yard.
  6. #6 Re: Replacing AC components
    Charles City, IA
    No need to flush it and I agree with cam.
    SMGPFC Two Nipple General
  7. #7 Re: Replacing AC components
    I see you aimed for the orifice tube. Good call. Here's what they can look like
    I'd do the rest of the underhood seals while you were there. A seal kit is cheap insurance against leaks.
  8. #8 Re: Replacing AC components
    SE Level Member Storm Smith's Avatar
    Mar 2012
    Arkansas
    I originally thought my A/C going hot was a problem with the compressor. Turns out thanks to some UV freon that there is a leak around the high pressure valves where you plug your gauges in when recharging the A/C. We are going to replace them this weekend after we use our vacuum to collect the freon that hasn't leaked out.
    Quincy, Mass
    Make sure you have the good pack of Ac orings if the stuff doesnt come with them.
    No more GP 04 Impala SS Indy:
  10. #10 Re: Replacing AC components
    May 2008
    Bill,
    That's pretty nasty looking. Glad I got it. I've heard it's a terrible pain to get to?
    Would this seal kit likely have everything I would need?
    http://www.rockauto.com/catalog/moreinfo.php?pk=1251518
    Thanks for all the help guys.
  11. #11 Re: Replacing AC components
    Mar 2012
    Arkansas
    Turns out replacing the high pressure valves didn't get rid of the leak. But it did slow it down. We have used ultraviolet freon and a freon detector and nothing. We can't think of anything else that we can do besides taking it to the dealer.
  12. #12 Re: Replacing AC components
    May 2008
    The evaporator is housed inside the car behind the dash. If you're not seeing any leaks in the engine bay, maybe the leak is coming from there? Good luck getting to it though. From what I can tell it requires removing the whole dash.
  1. 6.5 components in front door
    By blakgtp in forum Audio, Security & Visual Electronics
    Last Post: 10-09-2011, 06:28 PM
  2. Interior Components
    By cowmilker08 in forum General Tech Discussion
    Last Post: 04-01-2009, 01:59 PM
  3. L67 components
    By straight_upprix05 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-30-2008, 08:01 PM
