Thread: A/c heat not blowing anymore
Results 1 to 6 of 6
  1. #1 Re: A/c heat not blowing anymore
    Aug 2012
    United States
    a bit off thread...but I just got a new battery and now the passenger side a/c is blowing hot air?
  2. #2 Re: A/c heat not blowing anymore
    Quote Originally Posted by Sharjco View Post
    your blend door actuator is hanging up, take the battery off again for 20 minutes or so, then hook it back up, some times they will straighten them selves out.
    after you hook the bat back up, sit in the car and just turn the key to run let the dash light up and ding, hit auto on the climate control, with any luck it will be normal again.
    i only suggest this trick because it worked fine before you changed the battery is my guess.
    if this happens with out touching the battery most of the time the blend door actuator is bad.
    the pass side is easy to get to at least, if this dont fix it, you can take the glove box off/out of the dash, and right on your left side you will see it, so you can unbolt it and turn the knob by hand to cold or heat.
    further info and diagrams. http://www.grandprixforums.net/blend...ent-21941.html
  1. Whats going on anymore
    By Below Average Joe in forum The Rant Forum
    Last Post: 06-28-2013, 10:58 PM
  2. 05 GP Air Conditioner Not blowing cold anymore
    By mpoynter31 in forum General Tech Discussion
    Last Post: 05-19-2012, 06:53 PM
  3. Not lurking anymore!
    By drunkonsunday in forum Introductions/Noob Questions
    Last Post: 01-12-2012, 04:07 PM
  4. No heat blowing in the car
    By jbaker4433 in forum General Tech Discussion
    Last Post: 11-19-2011, 06:00 PM
