OK, so I also have the same issue with my 06 base GP, low beams cut off for a period, high beams will still work but want to get to the bottom of this problem. What was the solution exactly? Was it a ground wire or a wire in the bulb socket itself?
Quote Originally Posted by izup69 View Post
I have the same problem in my 06 base. It was bare wireing for me. And it was also completly random backroads or highway didnt matter would just shut off then all of the sudden come back on. If you have ever removed the headlights and and put them back in or if the previous owner ever did this it is verry easy to stip the wires running to the bulb. if they get caught where the little plastic nub slips into place and u try to push down the retainer bar it will for sure stip them.
Check both headlights high and low beams and pay close attention to the wires. It may be hard to see. Hope this helps
