Thread: Car stalling at low rpms / reverse
Results 1 to 7 of 7
  1. #1 Car stalling at low rpms / reverse
    GT Level Member GTLGDP's Avatar
    Oct 2011
    New Jersey
    I was backing up, tapped the gas, and the car just stalled. Had to put it back in park and start it again. No problems at all starting it up either. Then I go to turn about a minute up the road and it did it again as I was slowly turning. Then on my way home, once driving down the street from a greenlight, the car wouldn't shift and the rpms just rised until I took my foot off the gas. Anyone know what this might be? After spending around $1500 already on repairs for this car more problems sounds horrifying. I have a 2000 GTP. No codes while it was happening, but a few days ago the ses was on for about 25 mins then shut off. Help me. I hate my life right now
  2. #2 Re: Car stalling at low rpms / reverse
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    i would have to say thats a good case of broken car sir ......... not sure never seen that one before
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  3. #3 Re: Car stalling at low rpms / reverse
    Replaced the crank sensor yet?
  4. #4 Re: Car stalling at low rpms / reverse
    Oct 2011
    New Jersey
    Do you think it would be a throttle position sensor?
    Edit: we posted the same time, no I have not replaced that but months ago I had a throttle position code but it went away and never acted up. The only other I changed in the engine block was a knock sensor.
    SE Level Member nathangartz's Avatar
    Nov 2008
    Milwaukee
    Grab a throttle position sensor and mass airflow sensor off amazon. Think they run around $70 shipped for both of them. I had the same exact problem with mine. It was the throttle position sensor. Grabbed the mass airflow sensor while I was at it because it was so cheap. When I pulled that out, I could tell it was a good idea to replace it, as it was all gunned up.
    Fired her up after that and she's been golden ever since.
    Easy fix and one you should be able to do yourself too! Think you just need a torx bit to take the screws out...
  6. #6 Re: Car stalling at low rpms / reverse
    How about we diagnose things before shotgunning parts? Have the code read. it's in history. Then let's go from there.
    Quote Originally Posted by GTLGDP View Post
    LOL, I love dramatic people. A little car problem and you post like it's the end of the world. Lemme know when someone you love dies.. then talk about how bad of a day you are having.
  7. #7 Re: Car stalling at low rpms / reverse
    Oct 2011
    New Jersey
    I've experienced loved ones passing away. It was late last and I was just pissed off about more problems my car was having.
    So, today i go to Advanced Auto and pick up a TPS even though they didn't have any torx t20/t15 safety bits. Went to a Napa down the street from there, they didn't have any either. After that i went to a local hardware store and still, no luck. Now i have a TPS i can't use at the moment.
  1. Stuttering at low RPMs
    By fri3dchick3n in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-20-2011, 08:38 PM
  2. No RPMs..?
    By GTBabyGirl in forum Audio, Security & Visual Electronics
    Last Post: 10-14-2011, 07:46 PM
  3. Fluctuating RPMs 05 GP
    By NegativeOne13 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-31-2011, 01:19 PM
  4. RPMs...??
    By SlowM90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-29-2009, 11:47 PM
  5. Stalling, low RPMs
    By jdamico84 in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-05-2009, 01:01 PM
