Thread: wheel bearing questions
Results 1 to 3 of 3
  1. #1 wheel bearing questions
    GTP Level Member Austins01GP's Avatar
    Nov 2010
    Maryville, MO
    well a while back i noticed that it sounded as if one of my rear wheel bearings was on it way out. at the time i didnt want to mess with it so i left it alone until it would get bad enought to replace. but it still hasnt gotten much worse, but heres the problem. now one of my front ones out of no where has become much louder than the rear in 2 days. the noise is much more noticible when the wheel is turned to the right, but after reasearch ive seen mixed answers about which wheel bearing is needing replacing.
    so the question becomes, replace just the one (after i find out which is bad), or all four? and whats the cost ill be looking at either way.
    thanks for the help
    // 1992 Nissan 300zx Twin Turbo (More RWHP than the Comp G)
    // 2005 Comp G
    CLICK ME!! for my Z Build and Comp G
  2. #2 Re: wheel bearing questions
    when you turn to right, the left wheel bearing has more load on it, thus would make more noise.
  3. #3 Re: wheel bearing questions
    Nov 2010
    Maryville, MO
    Ok thanks for clearing that up, makes sense
    might just fix the one
    // 2005 Comp G
  1. Wheel bearing/hub assembly questions
    By 01STOCKGTP in forum General Tech Discussion
    Last Post: 05-16-2015, 05:21 PM
  2. wheel bearing hub
    By learnAsUGo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2011, 09:43 AM
  3. ABS wheel bearing/hub on non ABS car?
    By Captain Bravo in forum Brakes/Suspension/Chassis
    Last Post: 01-01-2011, 03:15 PM
  4. Wheel Hub Bearing questions?
    By dew1520 in forum Brakes/Suspension/Chassis
    Last Post: 09-22-2009, 08:42 PM
  5. Wheel bearing questions...
    By Iron Indian in forum Brakes/Suspension/Chassis
    Last Post: 09-21-2008, 11:05 AM
