Thread: Whoa, ICM in half?
Results 1 to 6 of 6
  1. #1 Whoa, ICM in half?
    GT Level Member fri3dchick3n's Avatar
    Alaska
    Well I have been having this slight misfire on my GTP for a little bit. I would moniter it from my awesome aeroforce. Cyl 3 and 4 would misfire slightly. cyl 3 would be between 2-12 sometimes and cyl 4 would misfire between 2-6.
    I tried cleaning up the coils before and it helped only a little bit.
    New plugs gapped @ .055
    So I wanted to try to clean up the coils and confirm that it wasnt the problem and maybe rotate them around.
    When I pulled the last coil off this bracket piece was very loose and came off.
    Not sure what to do, Is this ok? Or time to get a new one?
    99 GTP: 3.4'' MPS, Overkill PCM, Intake, Catless SD Headers, TransGo Shift Kit, 180º Thermostat, Flipped Dog Bones
  2. #2 Re: Whoa, ICM in half?
    Alaska
    Ok, well I tried cleaning up the the square bronze prieces because they look important. I used some sand paper. Cleaned up the coils connectors to the plugs. Made the misfire worse. Cyl 3 & 4 now misfire up to 8 each. Coils were swapped so im now thinking, ICM connection somewhere or plug wires.
    Plug wires are AC Delco 7mm and were replaced Jan last year, I did not put the heat shields on them after the header install. Could that interfere with the wires over heating?
  3. #3 Re: Whoa, ICM in half?
    Got any friends with a 3800?
    If so, swap and ICM with them and see what the car does, if misfires go away, prolly the ICM at fault.
  4. #4 Re: Whoa, ICM in half?
    Alaska
    Ive only seen one other modded gtp here in Alaska, barely see him driving around too. Pretty much a lonewolf on this car. But I did. MOre reading and I guess it's common for these cylinders to misfire some at idle, I'll just leave them be as long as they don't get worse.
  5. #5 Re: Whoa, ICM in half?
    Your icm is not in half. that other part is the bracket it sits on.
  6. #6 Re: Whoa, ICM in half?
    Alaska
    Thanks, Yea I found out later on that its supposed to come apart like that.
  1. Whoa! Cracked window..
    By fri3dchick3n in forum General Grand Prix Discussion
    Last Post: 03-22-2012, 11:51 AM
  2. Whoa sign, you violent!
    By Explicit_Spade in forum Off Topic Discussion
    Last Post: 09-14-2011, 05:00 PM
  3. Possible kill story??? WHOA???
    By WHT98GTP in forum Track Sessions and Kills
    Last Post: 09-20-2009, 11:51 AM
  4. Whoa!
    By BackInBlack in forum Off Topic Discussion
    Last Post: 03-28-2009, 01:38 PM
  5. whoa a graph
    Last Post: 02-20-2009, 12:58 PM
