Thread: Cold air intake
Results 1 to 20 of 22
  1. #1 Cold air intake
    SE Level Member Middy's Avatar
    Jul 2012
    Kansas City
    Bought one from chromeintakes off ebay.
    Trying to hook up, but unsure what to do. Here's what it looks like after the main filter box is off.
    There's an extra hose, not sure what to do.. and the electrical box thing that was in the filter.
    Here's it with it on..
    The hose has nowhere to go and I'm not sure if what to do with the electrical box thing below it.
    Comin' through you with no sign of Inertia!
  2. #2 Re: Cold air intake
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Welcome to the wonderful world of California delivered W-bodies.
    This is what happens when you buy anything "universal" of ebay. Hope you didn't spend too much money on it.
    GPONA #1 Cyber Bully
  3. #3 Re: Cold air intake
    Jul 2012
    Kansas City
    Quote Originally Posted by blackspike2710 View Post
    Yeah, I read about the california shiz.. then I saw the tag on my car by filter saying this was conformed for California laws or w/e, I was like d'oh.
    Spent $19 on it, so I'm not worried.
    /e: All I need to know is where to go from here.
  4. #4 Re: Cold air intake
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Considering CAI don't do anything, I'll let you decide.
  5. #5 Re: Cold air intake
    Jul 2012
    Kansas City
    Vague answers don't help me.
    Either respond with an idea that will help me or don't post.
  6. #6 Re: Cold air intake
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Put the air box back on.
  7. #7 Re: Cold air intake
    Thanks for your super helpful response. I can tell you will be an upstanding member here.
    Edit: you have my thanks.
    OP:
    Did it connect before or after the MAF?
  8. #8 Re: Cold air intake
    London Ont, Canada
    just from the angle, id say before Maf into back of box.. throw a screen on it and call it a day?
  9. #9 Re: Cold air intake
    If that is the case, little filter or some sort and call it a day.
    Hope there isn't a big fine for a non-CARB approved intake.
  10. #10 Re: Cold air intake
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    i would go to like autozone and buy one of those little beather filters and put it on it all it is is the freash air intake tube for the smog pump
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  11. #11 Re: Cold air intake
    SE Level Member Nathan07GP's Avatar
    Mar 2012
    San antonio
    Disconnect your MAF from that black sloppy hose. Go to oreilly advanced or pep boys and get a spectre coupler. Connect that couple from your maf to your throttle body. All that black rubber hose is doing is bottle necking your air flow. Dont do that its going to make things worse
  12. #12 Re: Cold air intake
    SWPA
    Quote Originally Posted by Nathan07GP View Post
    You're not going to get a Spectre coupler to hook it up that way. They are odd ball sizes, something like 3 1/4 or something.
    I ordered my couplers because Spectre ones weren't even close.
  13. #13 Re: Cold air intake
    London Ont, Canada
  14. #14 Re: Cold air intake
    Mar 2012
    San antonio
    My 3 inch coupler from weapon are worked on my TB and MAF. Spectre will work with a little bit of stretching and some lube from Seafoam Deep Creep. Thats what i did. Stretched in onto that ***** for a tight fit
  15. #15 Re: Cold air intake
    SWPA
    I prefer PROPER fitting, just in case it ever has to come apart again.
  16. #16 Re: Cold air intake
    Mar 2012
    San antonio
    Trust me in time after all the heat coming from the engine it kind of molds the coupler into the size you need it to be.
  17. #17 Re: Cold air intake
    SWPA
    Trust me. I have had to stretch couplers to get them to fit before, and the next time it had to be done it had to be stretched again. A coupler that is too small, will always be too small.
    High quality proper size coupler > Any Spectre Coupler (especially ones that have to be stretched to fit)
  18. #18 Re: Cold air intake
    Mar 2012
    San antonio
    Thats when i use to use spectre. My couplers of choice now are Weapon R
  19. #19 Re: Cold air intake
    Jul 2012
    Kansas City
    Like a boss.
  20. #20 Re: Cold air intake
    if you took off the rubber hose and put that filter on the canister below it'd look much nicer.
  1. Replies: 81
    Last Post: 02-14-2013, 02:57 AM
  2. Cold air intake
    By tonio301 in forum 5.3L V8 (LS4)
    Last Post: 06-05-2011, 08:03 AM
  3. Short Ram Air intake or Cold Air Intake
    By slopez in forum General Tech Discussion
    Last Post: 02-01-2011, 10:08 PM
  4. Help-cold Air Intake
    By sUpErClEaNbLaCkMaChInE in forum General Tech Discussion
    Last Post: 01-29-2009, 12:36 AM
  5. K&N Cold Air Intake
    By reallyfast1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-03-2008, 07:39 AM
