Thread: Cam
Results 1 to 20 of 21
  1. #1 Cam
    SE Level Member Nathan07GP's Avatar
    Mar 2012
    San antonio
    My car is not supercharged but it will be. Im looking to get a cam that will work with a car thats a daily driver.. Any Suggestions?
  2. #2 Re: Cam
    $800 DIY cost, 1200+ DIFM, its not worth it.
    Top swap and make the same power or save up for a Z3 kit and make more power than both.
    ZZP GT1 would be nice daily cam, GT2 sounds awesome though.
  3. #3 Re: Cam
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    XP cam or s1x can be daily driven, if you top swap.
    GT1 if your staying N/A, but i honestly dont think its worth it.
    Blue Nick DD his grand prix with an XP for 40k miles i believe.
  4. #4 Re: Cam
    XP cam or s1x can be daily driven.
    Reread the OP.
  5. #5 Re: Cam
    Jun 2011
    Reread the OP.
    He said hes going to be supercharged. Should throw in an XP while top swapping?
    I dont know.
  6. #6 Re: Cam
    I dont know.
    Man, I can't read, thanks.
    XP means 40K mile timing chain/dampener life. After that it needs to be freshened up. Probably the valve springs as well.
    VS is the ideal supercharged daily cam.
  7. #7 Re: Cam
    Jun 2011
    I thought i heard the VS was hard(er) to tune or something than the XP?
    But hell, i dont know much.
    Edit: Im wrong on that, i was thinking NIC cam.
  8. #8 Re: Cam
    Jan 2012
    Philadelphia
    isnt VS like the most mild cam? im going XP on mine and its a DD
  9. #9 Re: Cam
    Mar 2012
    San antonio
    So xp?
  10. #10 Re: Cam
    Vs is The least mild cam..can be ran on stock valvetrains.
    Xp/S1X require...upgraded valve springs/chain/tensioner etc
    you decide.
    04 Comp G.
  11. #11 Re: Cam
    xp s1x need upgraded valve springs. stock chain and tensioner.
  12. #12 Re: Cam
    Mar 2012
    San antonio
    Confusing.. so upgraded chain and tensioner or stock?
  13. #13 Re: Cam
    105 springs and stock fresh tensioner and chain.
  14. #14 Re: Cam
    VS cam with L76 springs.
  15. #15 Re: Cam
    I S1X'd for 50K then put 130#'s on and drove about another 5-10 or so.
  16. #16 Re: Cam
    If you're putting any cam in, you should put a new timing chain/tensioner in as well as new valve springs.
  17. #17 Re: Cam
    Mar 2012
    San antonio
    lol
  18. #18 Re: Cam
    Jun 2011
    Which one going with?
  19. #19 Re: Cam
    Mar 2012
    San antonio
    S1X i guess. Daily Driver
  20. #20 Re: Cam
cam
