Thread: Cradle is dropped, should I replace my PS rack while I'm there?
Results 1 to 13 of 13
  1. #1
    GT Level Member GTX's Avatar
    Apr 2008
    Vallejo,Ca
    Dex cool is a inferior coolant....flush that **** ASAP ...Dex cool is only known for causing problems...the revised lim gaskets are nice being a metal, but still Dex cool kills them...Dex cool is almost corrosive
    But on topic....if there is noting wrong with your rack why replace it? On top of added costs of the rack plus alignment...leave it alone
    COMP G
  2. #2 Re: Cradle is dropped, should I replace my PS rack while I'm there?
    Quote Originally Posted by GTX View Post
    I'm not a Dex lover, but you have it quite incorrect. Dex is not the same formula from 1996 when it first came out. You don't find a lot on that, but they've changed it to be less oaty. If air is introduced then it can become like oatmeal. If it's left in a car past it's service life it might become a bit acidic. Many people don't maintain their cooling systems properly because it keeps on working. Hence the issues.
    Me, I use anycolor ... one and done.
  3. #3 Re: Cradle is dropped, should I replace my PS rack while I'm there?
    Apr 2008
    Vallejo,Ca
    As a certified gm tech, I can tell you Dex cool is garbage.....from day 1 until now...only people that use/stick with Dex cool are the ones that don't no any better other than what the manual says....as far as the G-05 goes....it's made by zerex and is great...I use it now
    COMP G
  1. Jaw Dropped
    By LowRidinCrew in forum Off Topic Discussion
    Last Post: 03-06-2012, 03:53 PM
  2. Dropped my car...camber is off.
    By Ballin00gtp in forum Brakes/Suspension/Chassis
    Last Post: 11-28-2010, 10:21 PM
  3. Replace Magnasteer Rack with Regular Rack?
    By Smoker324 in forum General Tech Discussion
    Last Post: 06-29-2010, 09:11 PM
  4. Installing Cradle (cradle alignment pins)
    By JJ91284 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-16-2008, 05:47 PM
  5. Weird noise. Dropped the car in second.
    By Freebeer187 in forum General Tech Discussion
    Last Post: 08-04-2008, 12:26 PM
