Thread: When to get bigger fuel injectors
Results 1 to 20 of 22
  1. #1 When to get bigger fuel injectors
    GT Level Member RideWithPride's Avatar
    Oct 2011
    when?
  2. #2 Re: When to get bigger fuel injectors
    Florida
    When you start to run the factory injectors static.
  3. #3 Re: When to get bigger fuel injectors
    Why do you ask so many questions?
    Why dont you never read before you post?
    Why has this topic been asked like 100 times?
    You wont learn anything when all you do is asking questions and never get the right answers.
  4. #4 Re: When to get bigger fuel injectors
    Oct 2011
    If it makes you feel better i just got rod knock agian on my 4th engine and wasted all the savings i had on i guess asking was bad!
    Amen brother. I just stopped replying to them..same questions has been asked 3 billion times...SEARCH the forums and stop being lazy.
    Sent using Tapatalk.
    04 Comp G.
  6. #6 Re: When to get bigger fuel injectors
    Out West
    Quote Originally Posted by RideWithPride View Post
    when?
    Canned tune + Supporting mods + 3.3-3.4
    Street tune + Supporting mods + 3.1
    Whine with your Cheese?
  7. #7 Re: When to get bigger fuel injectors
    Quote Originally Posted by Nixon View Post
    Or anything past a stock pulley on a top swap.
  8. #8 Re: When to get bigger fuel injectors
    Out West
    Lol.
    You referring to stock l36 or stock l67 injectors?
  9. #9 Re: When to get bigger fuel injectors
    Ohio
    sums it up ^^^
  10. #10 Re: When to get bigger fuel injectors
    Well I dont think L36 injectors would cut it.
    L67 flow some fuel, but they're all old and filled with crap these days.
  11. #11 Re: When to get bigger fuel injectors
    Out West
    I'd think with a decent street tune you'd be able to go down to a 3.4 on l67 injectors top swapped.
  12. #12 Re: When to get bigger fuel injectors
    Lawngoose tried that.
    Didn't work well.
    I never had an opportunity to try, only two of my L67 injectors worked.
  13. #13 Re: When to get bigger fuel injectors
    Out West
    Perhaps with a chiller.
  14. #14 Re: When to get bigger fuel injectors
    Jan 1970
    Maquoketa, Iowa
    Scanner should be the first thing you ever buy before touching a 3800 and the second thing you should ever do is learn how to use it.
  15. #15 Re: When to get bigger fuel injectors
    Oct 2011
    Quote Originally Posted by FoSHO99 View Post
    even a all stock gtp?
  16. #16 Re: When to get bigger fuel injectors
    Florida
    Good lord, 4th engine with rod knock??
  17. #17 Re: When to get bigger fuel injectors
    The engine problems is not your fault, its the shop fault for not rebuilding the motor correctly.
    Your only at fault for not taking the time to learn and understand about these cars and what the mods can do to them.
    Asking questions to simple things is what annoys "us" the most because of the fact that its been covered many many times before you've asked it.
    It's the only reason I say what I say.
  18. #18 Re: When to get bigger fuel injectors
    -Stock Gtp have knock you know.
    -Echoing what Fasho said first investment should be some type of scanner.
    -Shops at fault for not rebuilding your motor correct.
    -Your at fault for not searching enough on the forums...like Fivefinger said...it doesn't bother us when threads come up that are not common but when you bring up a topic that's been answered a billion times.. it gets to us.
    04 Comp G.
  19. #19 Re: When to get bigger fuel injectors
    Oct 2011
    commiting suicide tonight goodbye cruel world i had my run but i guess everything thing knocks over time
  20. #20 Re: When to get bigger fuel injectors
    Thats never a good idea, hopefully you aint serious.
    But what we have said is kinda true, you live and learn and I'm sure the shops going to fix it right, because its there fault.
  1. when to get bigger fuel injectors?
    By pontiacmanj2 in forum General Grand Prix Discussion
    Last Post: 05-31-2012, 02:21 AM
  2. 97 GTP fuel injectors
    By DSkyles in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2009, 11:22 PM
