Thread: Why Does My Gas Gauge Not Work?
Results 1 to 12 of 12
  1. #1 Why Does My Gas Gauge Not Work?
    Peachtree City GA
    so i have an 01 GTP and ever since i got it, the gas guage dosent quite work right when it's full it 'll read full and when it s really low it 'll read low but anywhere in between it can be random of corse this effeccts my mile to empty guage BUT my fuel used guage works to the T so ive been using it to know when im low but i still get caught on the side of the road every 5 mos or so with no gas, the fuel used guage can be .3 or so off sometimes... so what's wrong with the car? ive heard things like it's the fuel sending unit or i need a new fuel pump which is it?
    GTP Level Member TyroElite's Avatar
    Williamsport, PA
    I'd venture to guess its the sending unit. Could be the float is getting stuck. I think if your fuel pump were going bad, you'd have more serious problems than a faulty gauge
    Peachtree City GA
    i know its not the pump it self but a mecanic said that the pump and the sending unit are in one unit so u can't replce just the sending unit...
    GTX Level Member webracin's Avatar
    Arkansas
    I think thats a problem with alot of GP's.....I get about 200 miles out of the first 1/2 tank and 100 miles out of the last 1/2 tank.....My DIC is about 2 gallons off every time...I can put 17.3 gal in the tank and it says I used 15.4
    webracin
    FYI...If you need a sending unit get in touch with GTPMORAD he may have one for ya.
    2001 Grand Prix GTP
    ZZP HUB 3.2 3.4, ZZP 8 Rib conversion, JC 3" DP Gen 2 cat & U-bend Delete, Accel Super Stock 8mm wires, DHP 1.5, 180* Thermo, Throttle Spacer, SS Intercooler, ZZP Fuel Rails, SLP CAI w/K&N Cone, Dynomax cat back, ZZP Tranny.
    2000 Grand Prix GTP Daytona K&N, Flowmasters
    PA
    I had a similar problem with my first GP. The gauge would work fine till it got down towards a quarter tank. Then it would fluctuate a little. And when it was really low, it would read full. So I pulled the pump assembly and replaced the entire thing with a good used one from Ed.
    The used pump was pretty cheap and damn easy to replace with the help of the access hole. Took me about an hour to do. Not sure what the cost of the pump was as it was a couple years ago. But I would say I am 99% certain that your sending unit in your pump assembly is bad. But not sure if you can get just the sending unit and replace it. Ed would know for sure.
    2001 GSE
    Peachtree City GA
    who's ed and how do i ask him?
    Arkansas
    GTPMORAD is Ed.....Ed Morad is the best used parts guy around.....
    webracin
    gtpmorad@msn.com
    2001 Grand Prix GTP
    Tulsa, Oklahoma
    haha, I just posted this to the electrical forum…
    Williamsport, PA
    Your post is moved over here now too. I left it open for now but if you can find everything you need here, we can close it and condense the information.
    PA
    Quote Originally Posted by webracin View Post
    gtpmorad@msn.com
    You are correct that Ed is the best used parts guy around. But I always send my emails to GTPED@msn.com
    2001 GSE
    Saraland Alabama
    my only issue with a used one, is the seer number of failures on the stock sender. Has anyone used a new aftermarket one and had any longevity from it? I'd hate to buy a used one and have it do the same thing next year
  12. #12 Re: Why Does My Gas Gauge Not Work?
    May 2024
    Montana
    Quote Originally Posted by TyroElite View Post
    I just bought a 96 GP SE and the fuel gauge bounces from empty to full unless I fill the tank. Does anyone know how to replace the sending unit?
