Thread: colder sparkys?
Results 1 to 7 of 7
  1. #1 colder sparkys?
    GT Level Member RideWithPride's Avatar
    Oct 2011
    I read in safely modding you gtp you should put colder plugs in but does it give you any hp gain and also i heard that you should use stock wires since they have a low fail rate.
  2. #2 Re: colder sparkys?
    ....question?
    you dont need colder spark plugs until you run more boost.
    stock wires perform great and are the cheapest out of all the other choices.
    more?
  3. #3 Re: colder sparkys?
    Quote Originally Posted by RideWithPride View Post
    If you read that thread then this info wouldn't be coming out of yer dome.
  4. #4 Re: colder sparkys?
    Oct 2011
    how do they work/ what does it do?
  5. #5 Re: colder sparkys?
    What does what do?
  6. #6 Re: colder sparkys?
    Oct 2011
    What does what do?
    What do colder spark plugs do? Headers add more flow and protect agianst KR so what do cold pluggies do?
  7. #7 Re: colder sparkys?
    You want to run the hottest spark you can, always.
    Stole this from another forum.
    Colder plugs have less porcelain (the white part) than hotter plugs. The more porcelain the more a plug retains heat, in high HP cars where there is more heat it creates a hot spot in the cylinder which can lead to detonation. A hotter plug has a better lifespan, but obviously you want a colder plug that would retain less heat and NOT create that hotspot.
    Gapping doesn't really have anything to do with the heat of a plug, but obviously a tighter gap under boost would lower the chance of spark blow out. It's different on every car though, for example, mine would blow the spark out at .030, but is fine at .028.
  1. colder plugs???
    By Jtg1551 in forum General Grand Prix Discussion
    Last Post: 07-07-2012, 10:44 PM
  2. A/C Colder on Passenger Side???
    By nikkigpgt00 in forum General Tech Discussion
    Last Post: 07-05-2011, 11:50 PM
  3. Colder plugs early
    By klj5022 in forum General Tech Discussion
    Last Post: 05-12-2011, 10:51 PM
  4. opinion on colder plugs
    By tjvdubsport in forum General Tech Discussion
    Last Post: 06-04-2009, 12:48 PM
  5. Colder spark plugs
    By offroadfury6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2008, 09:50 AM
