Thread: At a loss here.
Results 1 to 5 of 5
  1. #1 At a loss here.
    Jul 2012
    Midland
    Last week my fuel pump went out. Got fuel pump in today, installed, car started right up... for about 10 minutes. Car sputtered and died. Figured I'd run to town and get a fuel filter, which was on today's things to do anyways. Replaced the fuel filter. Old one was clogged and figured it was the suspect. Went to start the car, and it ran like CRAP. Was definitely misfiring. The engine was shaking badly and the exhaust had a loud THUD THUD THUD sound to it. But no codes got thrown. Sprayed just a quick spurt of starting fluid into the intake to see if idle picked up, but it just bogged down and I heard a loud pop coming from the front driver's side of the engine. Don't know if it came from the exhaust or what. But still no code. I pulled the front plugs and tested for spark, and they are definitely sparking. I also noticed that with the plug removed and me cranking the engine, no fuel came out of the spark plug hole. Should fuel have come out? Anyways, when the car was running crappy, I played with the shrader valve on the fuel regulator and a decent amount of fuel came out. After the pop, no fuel is coming out of the shrader valve. I then took the fuel regulator completely out, put a rag in the hole, and fuel is definitely getting to at least the regulator. I have to buy a new regulator now anyways because I broke it myself, but what else is going on here? No codes are being thrown, and now the car just cranks but wont start.
  2. #2 Re: At a loss here.
    Jun 2012
    baltimore
    just a suggestion i am not sure but does the throttle body seem ok?
  3. #3 Re: At a loss here.
    GT Level Member Shiftingshaddow's Avatar
    KC
    I'm at the car cranks but no start but a different scenerio as to how it got there. I hate cars. Except for when I like them....
  4. #4 Re: At a loss here.
    Jul 2012
    Midland
    Throttle body is fine. Gonna pull the park avenue fuel rail off and put the grand prix one back on. Couldn't find the right fuel regulator for the park avenue fuel rails. So I got one for the grand prix. Will just swap the injectors back over and put the grand prix fuel rails on with the new fuel regulator. If that doesn't fix it, will test the new fuel pump again. It works, but don't know if its working as good as it should be.
  5. #5 Re: At a loss here.
    Aug 2012
    United States
    Is your ecm fuse blowing under the dash? Have a similar issue with a 2003 SE 3.1
  1. One Loss and One Win... so far
    By Kolton Lock in forum Track Sessions and Kills
    Last Post: 03-31-2012, 07:56 PM
  2. Loss of HP
    By black plague815 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-01-2011, 11:38 AM
  3. another loss of power :S
    By ChdMcD in forum General Tech Discussion
    Last Post: 07-31-2010, 07:08 PM
  4. loss/win
    By WhiteDevil in forum Track Sessions and Kills
    Last Post: 10-14-2009, 11:39 AM
  5. Might get my first loss....
    By Mvfootball1 in forum Track Sessions and Kills
    Last Post: 04-10-2009, 07:44 PM
