Thread: gas leak possibility
Results 1 to 4 of 4
  1. #1 gas leak possibility
    Jan 2013
    McKeesport,Pa
    I get a gas smell from my engine compartment but only when the engine is cold. What could cause this? The car seems to run fine. I am going to have it checked out. Also, does anyone know where I can get those flimsy blabk trim pieces that run along the top of the inner door panels. I have a 2000 GT. Thanks
  2. #2 Re: gas leak possibility
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    mods?
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  3. #3 Re: gas leak possibility
    Sep 2011
    Copperas Cove, TEXAS
    Check the O-rings inside of the fuel lines connecting to the fuel rails, I had a leak there on my 97 GT.
    As for the crappy door panel trim, the Junk Yard is your best bet or check the for sale section for some better door panels.
  4. #4 Re: gas leak possibility
    Pull the loom off the fuel lines. Turn the key to on, but not start and look for any pinhole leaks.
  1. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  2. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  3. Any possibility of reusing low mileage LIM gasket?
    By benner in forum General Tech Discussion
    Last Post: 09-13-2011, 07:43 AM
  4. Possibility of saving motor
    By FordMan77 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-10-2010, 12:11 PM
  5. Unpowered seats to powered seats? A possibility?
    By GrandPrixFan in forum General Tech Discussion
    Last Post: 09-08-2010, 10:31 AM
