Thread: 99 GTP Motor Swap over next 3 weeks - where to put jack stands?
Results 1 to 5 of 5
  1. #1 99 GTP Motor Swap over next 3 weeks - where to put jack stands?
    Cambridge, Ontario Canada
    Definately not going to use outside body perimeter frame (rocker area), too many times I have seen those give out and destroying the car. I will be using jack stands and car may be up there for 3 weeks. Where is best locations? pics would be great too.
    2005 E55 - stock
  2. #2 Re: 99 GTP Motor Swap over next 3 weeks - where to put jack stands?
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    pulling from top or bottom?
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  3. #3 Re: 99 GTP Motor Swap over next 3 weeks - where to put jack stands?
    Subframe. I typically jack from the front of the subframe in the center. Then you can jackstand at your back subframe mounts. It'll make the car pretty high up though.
    My suggestion would be to get some lower blocks that have the tires a little off the ground for most of the work and then have stands for when you need to be underneath working on the exhaust.
    Why three weeks?
  4. #4 Re: 99 GTP Motor Swap over next 3 weeks - where to put jack stands?
    Three weeks cuz i got no time - i hope to do it sooner but that would be worst case scenario.
    2005 E55 - stock
  5. #5 Re: 99 GTP Motor Swap over next 3 weeks - where to put jack stands?
    OK, so blocks on the cradle or on the "frame" rails (not perimeter frame)?
    2005 E55 - stock
  1. This is why you use an extra jack or jack stand.
    By Taz Magister in forum Off Topic Discussion
    Last Post: 06-25-2011, 10:48 PM
  2. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
  3. where to place jack stands?
    By twoleos617 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-18-2009, 11:50 AM
  4. Question still stands?
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-04-2008, 10:23 AM
  5. GTP actually stands for...?
    By DnaProdigy in forum Off Topic Discussion
    Last Post: 09-17-2008, 01:54 PM
