Thread: emergency please help!!!
Results 1 to 20 of 21
  1. #1 emergency please help!!!
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    Alright so I have the wbody store 12" brake upgrade and while I was driving today the bolt that holds the caliper to the slide fell out!!! What should I do I know I need to replace it but how??? What would I ask for at a parts store?
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  2. #2 Re: emergency please help!!!
    parts store, you need a hardware kit for a 2000 and up camaro front caliper.
    google it up first so you can see what your getting.
  3. #3 Re: emergency please help!!!
    Oct 2011
    Michigan
    OK I'm stuck at work all I know is that bolts missing and I can pivot the caliper off the rotor I hope there's no damage to the threads if there is what should I do buy a hole new kit from the w body store?
  4. #4 Re: emergency please help!!!
  5. #5 Re: emergency please help!!!
    Oct 2011
    Michigan
    There's 3 different ones there?
  6. #6 Re: emergency please help!!!
    take your other bolt to the store with you, match it up.
  7. #7 Re: emergency please help!!!
    Oct 2011
    Michigan
    When I click it it takes me to this page and there's 3 choices each a dollar more then the last
    Brake Caliper Bolt/Guide Pin | 2000 Chevrolet Camaro 8 Cylinders G 5.7L SFI | AutoZone.com
  8. #8 Re: emergency please help!!!
    you lost the short bolt that holds the caliper on right?
    the bottom and top bolt are the same, just take off the other bolt from the car and go to the store with it, match the new one, to the one you have.
    thats the safe way to go about it.
  9. #9 Re: emergency please help!!!
    Oct 2011
    Michigan
    Yeah ill do that its the bolt that holds the slide and caliper together. Hopefully the threads aren't messed up
  10. #10 Re: emergency please help!!!
    wont matter, cause you'll be getting the new sliders with the new bolts. if your rubber boots are worn, get a set of them too.
  11. #11 Re: emergency please help!!!
    Oct 2011
    Michigan
    Really? That link you posted didn't have slides it was just bolts
  12. #12 Re: emergency please help!!!
    this is the pic on the site, this is the bolts, and sliders.
  13. #13 Re: emergency please help!!!
    Oct 2011
    Michigan
    alright it makes more sense now
    this is what it looks like on my car hopefully i can just screw a new bolt in and be good to go
  14. #14 Re: emergency please help!!!
    thats all it should take.
    snug this one up good this time will ya lol
  15. #15 Re: emergency please help!!!
    Oct 2011
    Michigan
    haha i have no idea how this happened the F body brakes have been on my car for probably 3 weeks now, i heard the bolt fall out today when i hit a bump in the road, damn michigan roads
    Put a bit of locktite on them in the future.
    Sent using Tapatalk.
    04 Comp G.
  17. #17 Re: emergency please help!!!
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    Quote Originally Posted by asite57 View Post
    i dont think you had it as bad as me bro, my caliper to steering knuckle top bolt fell out, top of caliper fell down and wedged my wheel and locked it up,
    i had just exited the highway and had almost came to a stop, about 20mph, all of a sudden wheels locked up and i screetched tires, car would not move.
    i heard something bang under the car about a few miles back.
    luckily caliper and knuckle were salvagable, rim was scratched up pretty good inside, but no real damage. it was a miracle it did not happen on the highway.
    i had never even taken the brakes off, previous owner must not have tightened them down.
    i got some red loctite and torqued them to manufacturers spec of 147 ft-lbs. none of the bolts have moved since ;-p
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  18. #18 Re: emergency please help!!!
    Oct 2011
    Michigan
    Well got the part and fixed it up thanks everyone
  19. #19 Re: emergency please help!!!
    GT Level Member Adidasdude1989's Avatar
    Jan 2012
    Sturgis, MI
    Yeah i can relate to the Michigan roads, i feel your pain Same as Michigan winter, some cities use salt some dirt. Eats our cars away...
    Miles: 170-XXX
    Engine: 3.8L V6
    http://youtube.com/KBsVlog
  20. #20 Re: emergency please help!!!
    Donating Users str3etgl0w's Avatar
    Jun 2011
    Saginaw Mi
    Hell yeah our roads are awful in Michigan and the sad thing is they said we saved so much money in salt last year that they were Gunna fix a lot.more of our roads......... Don't see that happenING
  1. Emergency, stuck and need help
    By FriboRage in forum General Tech Discussion
    Last Post: 08-16-2011, 05:53 AM
  2. Emergency brake gone
    By BlackJack in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2009, 08:49 PM
