Thread: How to remove stuck gasket from throttle body?
Results 1 to 20 of 21
  1. #1 How to remove stuck gasket from throttle body?
    GT Level Member RideWithPride's Avatar
    Oct 2011
    So i got my throttle body off and cleaned it out but my head gasket is done for, how can i remove it without really scratching the metal, i tried a screwdriver but it left deppish scratches and thats not good.
  2. #2 Re: How to remove stuck gasket from throttle body?
    razor blade or puddy knife works well.
    scrape both sides clean
  3. #3 Re: How to remove stuck gasket from throttle body?
    Oct 2011
    puddy knife huh?
  4. #4 Re: How to remove stuck gasket from throttle body?
    GTP Level Member winterstorm's Avatar
    Jun 2012
    Connecticut
    if you have an air tool with a grinder or wire brush attachment you can you that. my dad did that to get a stuck gasket off my downpipe when i installed my catback. you must be very careful though.
    2005 Grand Prix GT
    Corsa Sport Catback, Thrasher Shift Kit, Custom Open Cone Intake, Spyder Chrome CCFL Halo Projector Headlights, CG LED Tail Lights, Pioneer DEH-33HD stereo unit, Alpine SPR-60C 2 way 6 1/2's, Kicker KS 6x9's
  5. #5 Re: How to remove stuck gasket from throttle body?
    Oct 2011
    quick question how can i clean the metal around it? like and chmical i can go get and spray it with?
  6. #6 Re: How to remove stuck gasket from throttle body?
    Jun 2012
    Connecticut
    you can get autoparts cleaner that you can just let it soak in it and brush it off with a wire brush. my dad has some its literally called autoparts cleaner.
    2005 Grand Prix GT
  7. #7 Re: How to remove stuck gasket from throttle body?
    Jun 2012
    Connecticut
    just be careful of the maf sensor, i dont know if i would do that unless you can remove it.
    2005 Grand Prix GT
  8. #8 Re: How to remove stuck gasket from throttle body?
    SWPA
    3M makes disks that attach to a drill that work wonders for gasket material.
  9. #9 Re: How to remove stuck gasket from throttle body?
    Jun 2012
    Connecticut
    ^^that would probably be your best bet^^
    2005 Grand Prix GT
  10. #10 Re: How to remove stuck gasket from throttle body?
    heres the cheap skate way to make it shine, go inside grab one of them sponges with the scotch brite pad kinda scrubby side, dry, and scrub the crap out of the gasket mating surfaces.
    or go get a scotch brite pad. green or red would work well for this.
    i would just scrape it off with a razor tho. and be done with it.
  11. #11 Re: How to remove stuck gasket from throttle body?
    SWPA
    The 3M disks are cheap and work WAY better and are a lot faster.
  12. #12 Re: How to remove stuck gasket from throttle body?
    Oct 2011
    gasket removal worth it because im nicking the surface with razor blade
  13. #13 Re: How to remove stuck gasket from throttle body?
    Put the blade nearly flat
  14. #14 Re: How to remove stuck gasket from throttle body?
    been using razors for 20 years, and sharp hand held wood chisel's.
  15. #15 Re: How to remove stuck gasket from throttle body?
    The 3M disks (known as cookies) should not typically be used as you can easily wear down part of the aluminum if you aren't proficient.
    There is a thing called gasket remover. I've seen it in an aerosol. Never tried it though..I'm proficient.
  16. #16 Re: How to remove stuck gasket from throttle body?
    Florida
    Permatex gasket remover...comes in an aerosol or a gel/liquid.
    Apply to the gasket, wait a few minutes, and scrape off...works wonders.
    But, about 5minutes with a razor blade will work fine.
  17. #17 Re: How to remove stuck gasket from throttle body?
    Topeka, KS
    Gasket scrapers work wonders
  18. #18 Re: How to remove stuck gasket from throttle body?
    Florida
    They do most of the time, but when you're working on a small piece like the TB, it's easy to slip and gouge your hand really bad. And yes, it hurt like all hell.
  19. #19 Re: How to remove stuck gasket from throttle body?
    Oct 2011
    so far im really frusterated with this since ive put 3 hours into this and theirs still somehwat alot of gasket left and i am nicking it constantly helllp
  20. #20 Re: How to remove stuck gasket from throttle body?
    I use a wire brush attachment on my drill.
  1. How do I remove the throttle cable?
    By Boostdreamer in forum General Tech Discussion
    Last Post: 10-09-2011, 05:48 PM
  2. Throttle stuck
    By MIke79 in forum General Tech Discussion
    Last Post: 06-14-2011, 09:35 AM
  3. Shifter button stuck?? Cant remove key
    By PRIXSY in forum General Tech Discussion
    Last Post: 02-25-2009, 07:45 PM
  4. Throttle body gasket?
    By Onthebrinc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-17-2008, 10:46 PM
  5. Can I remove the throttle body screen??
    By TDCRacing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-09-2008, 09:00 AM
