Thread: boost question
Results 1 to 14 of 14
  1. #1 boost question
    Donating Users str3etgl0w's Avatar
    Jun 2011
    Saginaw Mi
    Ok so I got a 02 grand prix gt I just dropped a l67 into it . I am using my stock gt harness so my question is what do I do about my boost controller? I would like them to run normal I do have a gtp harness I can get connectors from I just don't know how to wire it up or if there is a different route I should take. I dunno let me know what you guys think any help would be great
  2. #2 Re: boost question
    GTX Level Member blackflag's Avatar
    Virginia
    Your turbo?
  3. #3 Re: boost question
    Jun 2011
    Saginaw Mi
    No supercharger but I am using a gt harness
  4. #4 Re: boost question
    Hagerstown,Md
    boost controller isnt going to work. the blowers have a boost bypass valve thats vacuum operated. if your using the GT harness you need l67 injector connectors and Easy Performance - L67 Swap Kit #EP-L36-L67SWAP this
  5. #5 Re: boost question
    Jun 2011
    Saginaw Mi
    I have already wired new injectors and map car starts right up and seems run well I was just told I would have to do something about my bc there nothing pluged in to my bypass control or whatever its called sorry this is my first build kinda learning as I go lol so I don't know a lot of the proper names
  6. #6 Re: boost question
    Hagerstown,Md
    be sure to leave the bottom nipple open or the BBV will not close the whole way
  7. #7 Re: boost question
    Hagerstown,Md
    Okay, All that you need is a vacuum line that doesnt see boost running to the BBV. This is mine
  8. #8 Re: boost question
    Jun 2011
    Saginaw Mi
    Lol ok leave the nipple open then?
  9. #9 Re: boost question
    Jun 2011
    Saginaw Mi
    So just unplug the vac line to the bbv? And block off the opening?
  10. #10 Re: boost question
    Hagerstown,Md
    no run a vac line from the top of the blower to the top nipple on the bbv, leave the side/lower nipple to vent/open.
  11. #11 Re: boost question
    Jun 2011
    Saginaw Mi
    Lol ok this is Gunna sound retarded but run the vac from the little round cylinder on top of the super charger to the big round one?
  12. #12 Re: boost question
    Hagerstown,Md
    the large vaccuum port on top of the blower near the throttle body yes, run a line from that to the BBV thats located right in front of it.make sure you attach it to the top nipple
  13. #13 Re: boost question
    Jun 2011
    Saginaw Mi
    Awesome thanks man maybe you can answer my other question what's that little triangles box in front of .the bbv it suppose to have something plugged into it but I don't know what
  14. #14 Re: boost question
    Jun 2011
    Saginaw Mi
    Lol ohhh that's what I am unhooking the vac line from huh I just went out and looked
  1. boost gauge question
    By gtpeddie in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2012, 07:16 PM
  2. voltage boost question
    By LAIDBACKLUKE in forum General Tech Discussion
    Last Post: 05-16-2010, 05:05 AM
  3. boost gauge question
    By GMPUNK in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-26-2010, 12:32 PM
  4. Volatge Boost Mod question
    By abuckley1290 in forum General Tech Discussion
    Last Post: 04-04-2009, 01:30 PM
  5. question about boost gauge on a 98 gtp
    By millfire517 in forum General Tech Discussion
    Last Post: 02-09-2009, 08:31 PM
