Thread: Oxygen Sensor/Catalyst
Results 1 to 15 of 15
fakir Oxygen Sensor/Catalyst 07-18-2012, 03:09 PM
gtman98 Re: Oxygen Sensor/Catalyst 07-18-2012, 05:28 PM
blueguy Re: Oxygen Sensor/Catalyst 07-18-2012, 05:38 PM
Fivefingerdeathpunch Re: Oxygen Sensor/Catalyst 07-18-2012, 08:51 PM
fakir Re: Oxygen Sensor/Catalyst 07-18-2012, 09:41 PM
BillBoost37 Re: Oxygen Sensor/Catalyst 07-19-2012, 06:17 AM
fakir Re: Oxygen Sensor/Catalyst 07-21-2012, 05:11 PM
REDCRAPGP Re: Oxygen Sensor/Catalyst 07-21-2012, 06:38 PM
Rico Re: Oxygen Sensor/Catalyst 07-21-2012, 06:44 PM
stealthee Re: Oxygen Sensor/Catalyst 07-21-2012, 08:13 PM
dbextreme Re: Oxygen Sensor/Catalyst 07-21-2012, 08:53 PM
matt5112 Re: Oxygen Sensor/Catalyst 07-21-2012, 08:57 PM
stealthee Re: Oxygen Sensor/Catalyst 07-22-2012, 08:34 AM
dbextreme Re: Oxygen Sensor/Catalyst 07-21-2012, 09:08 PM
matt5112 Good to know. 07-22-2012, 01:00 PM
  1. #1 Oxygen Sensor/Catalyst
    SE Level Member fakir's Avatar
    Mar 2012
    Edinburg, TX
    I had the check engine light on come on so I took it to O'reilly's and told me that it was the oxygen sensor and the catalyst. I really don't want to buy or replace the catalyst since it's very expensive. Do you all think that by changing the oxygen sensor the check engine will come off. By the way the guy at the store cleared the light for me but it came on a few minutes later.
    The car does turn on fine and rides just fine, but the CEL is very annoying.. any suggestions...
    '04 | GP | GT2 | 162K
    Not an Expert | Just for the love of working on cars
  2. #2 Re: Oxygen Sensor/Catalyst
    SE Level Member gtman98's Avatar
    Aug 2008
    Phillipston, Massachusetts
    this shoud be in the engine or 04-08 section bud not tryin to rip on you
  3. #3 Re: Oxygen Sensor/Catalyst
    No questions in the How To section.
    Moving to the correct spot.
    Thanks.
  4. #4 Re: Oxygen Sensor/Catalyst
    What is the exact code number.
    We need that to try and help your further.
  5. #5 Re: Oxygen Sensor/Catalyst
    Mar 2012
    Edinburg, TX
    he didn't give me code # I'll go tomorrow in the morning and I'll give them to you all
  6. #6 Re: Oxygen Sensor/Catalyst
    yeah..get the codes.
  7. #7 Re: Oxygen Sensor/Catalyst
    Mar 2012
    Edinburg, TX
    ok they gave me the following code:
    P0420
  8. #8 Re: Oxygen Sensor/Catalyst
    P0420 Catalyst System Low Efficiency= ECM, PCM.
    Yup you need a new Cat. Bill will probably chime in. Gm warranty their original cats for 10 years or 80k so your cat would be out of warranty. Easy and cheapest thing to do is either replace it w/ a universal cat such as magnaflow and have a exhaust shop weld it on or if your state doesn't have emissions you could just put a pipe in it's place.
    04 Comp G.
  9. #9 Re: Oxygen Sensor/Catalyst
    Apr 2009
    Fort Worth TX
    Could also be the down stream O2 sensor but probably the catalyst.
  10. #10 Re: Oxygen Sensor/Catalyst
    SWPA
    When I threw that code it was because of an exhaust leak before the cat.
  11. #11 Re: Oxygen Sensor/Catalyst
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    IF you change your cat may I suggest:
    ZZPerformance - Catalytic Converters #ZZ-CATC
    AND
    ZZPerformance - Ubend Delete #ZZ-UBENDD
    The Ubend Delete isn't needed but while your exhaust guy is under there might as well...
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  12. #12 Re: Oxygen Sensor/Catalyst
    ZZP cats will set the P0420.
  13. #13 Re: Oxygen Sensor/Catalyst
    SWPA
    Not if you get the whole downpipe with the add on, which basically acts as a defouler, to not set the P0420.
  14. #14 Re: Oxygen Sensor/Catalyst
    Nov 2009
    Tennessee
    Then don't use the ZZP one.. LOL I was looking for the Magnaflow cat to post the link to but couldn't find it on ZZP, 3800performance, or intense.... I am pretty sure I bought mine from 3800performance a couple years ago for $80ish. Usually a muffler shop wants around $120 (here locally) plus for an universal cat that's why I went with the magnaflow one.
    I have passed emissions two years now with the Magnaflow cat.
    Good to know.
  1. Oxygen Sensor
    By mick777wauchope in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2012, 05:50 PM
  2. Oxygen Sensor
    By LowRidinCrew in forum General Tech Discussion
    Last Post: 06-15-2011, 12:55 PM
  3. Oxygen sensor queston.
    By Randy GP in forum General Tech Discussion
    Last Post: 06-01-2011, 11:51 PM
  4. Oxygen Sensor
    By BwolfGT in forum Off Topic Discussion
    Last Post: 11-21-2009, 05:44 PM
  5. oxygen sensor
    By grand2000prixgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-14-2009, 06:20 PM
