Thread: cam swap
Results 1 to 20 of 20
  1. #1 cam swap
    Jul 2012
    poughkeepsie ny
    Is it possile to cut a hole in the fenderwell on a 2000 ftp to swap the cam
  2. #2 Re: cam swap
    Why the hell would you do that? When you can just drop the cradle a few inches and pull it out through the passenger wheel well? I bet your trolling aren't you.
    04 Comp G.
  3. #3 Re: cam swap
    Jul 2012
    poughkeepsie ny
    Just where I live can't put it up in the air just thought maybe small hole could pull it out?
  4. #4 Re: cam swap
    Apr 2009
    Fort Worth TX
    If you can't drop the cradle and lift the car then lift the engine up. It's not hard to do.
  5. #5 Re: cam swap
    Jul 2012
    poughkeepsie ny
    How do I accomplish that?
  6. #6 Re: cam swap
    Jul 2012
    poughkeepsie ny
    Do i have to take the motor mount bolts out?
  7. #7 Re: cam swap
    Not trying to sound like a dick but if your asking these kind of questions your probably not ready for a cam install. Do some more research and use the search feature we have.
    04 Comp G.
  8. #8 Re: cam swap
    No you can't cut a hole in the wheel well, you'd compromise the structure of the body and likely have to cut the fender as well. The metal is thick enough that you'd require a plasma cutter to accomplish it.
  9. #9 Re: cam swap
    Apr 2009
    Fort Worth TX
    Big old hole saw? LOL
  10. #10 Re: cam swap
    From what he's saying Chuck, I agree with everything you guys already mentioned about either lower or lift. There aren't many people that will have access to a hole saw that will go through the main support structure where the cam is hiding.
  11. #11 Re: cam swap
    Apr 2009
    Fort Worth TX
    Yea, some of the sub frame is about 1/8" thick. LOL
    Do you have a write-up showing this guy how to lift the motor up a bit?
  12. #12 Re: cam swap
    Quote Originally Posted by Rico View Post
    A bit wouldn't help. You'd basically be pulling it. Lowering is easier, however if he can't lower then likely he can't pull it either.
    For all the write ups search "easy" and my SN
  13. #13 Re: cam swap
    Apr 2009
    Fort Worth TX
    This
  14. #14 Re: cam swap
    Topeka, KS
    Wow! That is all!
    Ohio
    So you're implying what here bill? ;p
  16. #16 Re: cam swap
    That I happen to have said "easy" about at least one thing in each write up. Might have said "this is not easy". Same word...lol Nah, it's all easy.
    Ohio
    Lol Nvm you didn't get the joke.... Probably the Alzheimers kicking in
  18. #18 Re: cam swap
    I got it and gave it right back.
  19. #19 Re: cam swap
    Jul 2012
    poughkeepsie ny
    Yea a write up on how to lift the motor a bit would be great somebody?
  20. #20 Re: cam swap
    Seems pretty "easy" to me
  1. l67 swap, trans swap
    By MrPhotographer06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2012, 07:11 AM
  2. Replies: 1
    Last Post: 12-31-2011, 04:55 PM
  3. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
  4. i need help on a swap
    By soloryder18 in forum Introductions/Noob Questions
    Last Post: 01-24-2011, 08:03 AM
  5. Top Swap
    By Vlad0691 in forum General Tech Discussion
    Last Post: 11-25-2010, 02:43 AM
