Thread: Rod knock on 3rd engine in less than 2 months?
Results 1 to 15 of 15
  1. #1 Rod knock on 3rd engine in less than 2 months?
    GT Level Member RideWithPride's Avatar
    Oct 2011
    moderated
  2. #2 Re: Rod knock on 3rd engine in less than 2 months?
    Should have bought a used engine?
    So do you have a question or should I move this into the rant section?
  3. #3 Re: Rod knock on 3rd engine in less than 2 months?
    Oct 2011
    ? rebuilt is supposed to be a step up why is it failing me what is so rigged on this car that it keeps killing my engine this car is all i have
  4. #4 Re: Rod knock on 3rd engine in less than 2 months?
    Quote Originally Posted by RideWithPride View Post
    No one rebuilds them properly and they fail just like yours have.
  5. #5 Re: Rod knock on 3rd engine in less than 2 months?
    Out West
    Rebuilt aren't the best option for 3800's
    Whine with your Cheese?
    Stock+Self Tuned. Going for low 14's everyday.
  6. #6 Re: Rod knock on 3rd engine in less than 2 months?
    Out West
    It's a GP.
  7. #7 Re: Rod knock on 3rd engine in less than 2 months?
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    did ya oil smell like gas, did ya have water mixing, did you prime the oil pump, was the bearings over torqued, was the bearings good from the beginning? why i ask because ive been thru this over the course of the past three months.. and finally up and running
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  8. #8 Re: Rod knock on 3rd engine in less than 2 months?
    Sounds to me like whoever did those rebuilds didn't know wtf they were doing.
  9. #9 Re: Rod knock on 3rd engine in less than 2 months?
    Well there's your problem.
  10. #10 Re: Rod knock on 3rd engine in less than 2 months?
    brunswick
    i "rebuilt" one and its holding... so im guessing we took our time and done it right..
  11. #11 Re: Rod knock on 3rd engine in less than 2 months?
    It may sound stupid but is your belt wrapped around the front or the back side of the water pump pulley. It should wrap around the front. YES it is possible to put it on with the right belt and everything work properly but the water pump will spin backwards and basically cavitate the coolant and it wont flow properly, plus the thermostat will act like a damn and make things worse when its flowing backwards. Just a thought I have heard of this before. Repeat engine grenades sounds like installed error.
  12. #12 Re: Rod knock on 3rd engine in less than 2 months?
    mi
    check your oil
  13. #13 Re: Rod knock on 3rd engine in less than 2 months?
    ^^^ if they dont CHANGE oil a few times when putting a rebuilt engine in a few times they shouldnt be around wrenches! Also from what ive heard engines should be ran with high zinc oil when rebuild the 1st few weeks.
  14. #14 Re: Rod knock on 3rd engine in less than 2 months?
    Quote Originally Posted by 98GrandPrixIraqVet View Post
    That was because engines used flat tappet cams.
  15. #15 Re: Rod knock on 3rd engine in less than 2 months?
    brunswick
    basically 5w 30 is used as break in oil...
  1. Replies: 17
    Last Post: 05-15-2012, 08:37 PM
  2. Engine Knock
    By tdm571 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-22-2011, 07:49 PM
  3. Engine knock???
    By MagnoliaMak in forum General Tech Discussion
    Last Post: 03-15-2011, 07:52 PM
  4. Need help, Engine Knock
    By valleyd01 in forum General Tech Discussion
    Last Post: 10-02-2009, 06:28 PM
  5. Do I have Engine knock?
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-02-2008, 07:59 AM
