Thread: 99 Grand Prix Stalling Probelms
Results 1 to 2 of 2
  1. #1 99 Grand Prix Stalling Probelms
    Jul 2012
    gladstone michigan
    We have a 99 grand prix and just recently it was having issues after you start it...it would run for a few seconds....and then die out...so spitting or sputtering ...just die. I am able to restart it after that happens but it is annoying. My daughter took it out and said it just died for her. Thinking it is a Mass Air Flow Sensor? What do you think? Could it be something else?
    SE Level Member 850Fishing's Avatar
    Jan 2012
    Florida
    First is your ses light on? I would allways start with the basics, check all vacuum lines, pull one of the front plugs and see if its dirty, if so change them, swap air filter. To troubleshoot the maf just unplug it and don't drive it hard. If it does not do it when the maf is unpluged then you have your culprit. It will throw a code of maf circuit too high so you will have to reset the computer to clear it. Also check the fuel pressure, get a guage from autozone and tap it Ito the port on the front fuel rail you should get 40ish psi. This is some stuff to try to get a better understanding of what's happening.
  1. my grand prix has been stalling out
    By dudek21 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 04:32 PM
  2. 95 Grand Prix GTP Stalling Issue??
    By james125 in forum General Tech Discussion
    Last Post: 02-21-2012, 06:36 PM
  3. Stalling Grand Prix?
    By WPT289 in forum Introductions/Noob Questions
    Last Post: 05-24-2011, 05:59 PM
  4. '98 grand prix gtp almost stalling
    By shawnooohhh in forum General Tech Discussion
    Last Post: 03-24-2011, 08:47 AM
  5. 02 grand prix is stalling
    By some dude in forum General Tech Discussion
    Last Post: 01-28-2010, 03:59 PM
