I am in need of a cruise control vacuum line diagram and A/C wiring diagram for 97 GTP!!! Please Help! sick of not having Cruise control and sick of not having ANY A/C! Any help is Appreciated!
Cruise control is not vacuum operated.
Check the fuses for the cruise control, also if your 3rd brake like bulb is burned out, the CC wil not work at all. If those both are fine, then you need to test for power and ground and you may even need to buy a new CC module, or get a junk yard one.
AC problem could be many thing, bad compressor, low on freon, too much freon, no power to compressor, leak in the system etc etc.
Maybe telling us what it is doing can help.
cruise control I will go and look at today..... A/C is a bigger issue ummm easiest way to explain this is on the compressor there is suppose to be a connector on it and mine dont there is a slot for it but the connector itself is not there! and I have no idea where it runs......
