Thread: need some help with switch over.
Results 1 to 7 of 7
  1. #1 need some help with switch over.
    GT Level Member Mikey Bonefas's Avatar
    May 2012
    Waterloo, IA
    Love the forums, glad i found it when i did.
    Been a big help ever since. So maybe you guys can help me out with this.
    I own a 97 GP SE 4dr, rear strut towers are completely blown out.
    I found another 97 GP GT 2dr, everything seems ok.
    I mean for 600 its not to bad.
    Its missing a couple things interior wise and i was just curious if there
    was/ is anybody out there that has made this same kind of switch over.
    What can i take out of my 4dr and put in the 2dr?
    Anything helps, window switches, seats, etc. etc.
    Like i said, any information would be helpful.
    Here is a small list of what im taking off mine to put on it, feel free to add something im missing.
    -front & rear rotors
    -possibly brakes(f&r)
    -wheels & tires
    -fuel pump
    -radiator
    Like i said, any help would be great.
  2. #2 Re: need some help with switch over.
    St. Louis
    Everything should swap over minus the door panels and window regulators. I'd leave the catfish front end and keep the GT front. Same for the rear.
  3. #3 Re: need some help with switch over.
    May 2012
    Waterloo, IA
    yeah thats what i was thinking.
    haha, never heard that bumper referred to as catfish.
    but yeah, Ive always liked the gt kit, glad the one im getting is complete.
    do you know if its easy to switch dash boards out?
    the gt has a cracked one and my se is flawless.
  4. #4 Re: need some help with switch over.
    I have a parts car coupe in the garage right now if you need any parts let me know.
  5. #5 Re: need some help with switch over.
    St. Louis
    Never tried swapping the entire dash. From doing heater cores on Ford's I can't say it would be much more fun to do it on a GP, lol... Just a PITA no matter what the car I would think.
  6. #6 Re: need some help with switch over.
    May 2012
    Waterloo, IA
    haha, my se is going to be my parts car.
    sucks though because i only have about a day to do it.
    but i appreciate the help with parts, if i need something after i send mine to the scarpyard ill PM you.
    would that involve removing the airbag, or can i leave that in place and still swap dashes?
    thats mostly my main concern. dont want to get punched in the face while trying to unbolt and remove it haha.
    i have a temper problem and id probably go haywire on parts of the car. andi wouldnt want tht.
  7. #7 Re: need some help with switch over.
    St. Louis
    If you manage to detonate the airbag I don't think beating up the car will be your first thought, lol...
    Disconnect the battery cables and let it sit for a bit. I think if you press on the brake pedal it will bleed off any residual power in the system. I think 10 min. does it for the airbag system but double check just in case. And IIRC the pass. airbag is bolted to the dash frame, so it would have to come out as well, or at least be disconnected from the electrical harness.
  1. Fan switch help
    By SerenityGTO in forum General Tech Discussion
    Last Post: 10-15-2011, 09:48 PM
  2. Trans switch/ e brake switch
    By Halbs in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2010, 02:57 PM
  3. Replies: 1
    Last Post: 02-01-2010, 10:18 AM
